niemi
#1 Posted : Saturday, September 7, 2019 1:31:56 AM(UTC)
niemi
Was thanked: 19 time(s) in 16 post(s)
We were switching in-program with three camera sources and a PIP. Very basic setup.
Out of nowhere, cut actions did not apply. Everything seemed responsive in the vMix interface but the cut actions didn't do anything.
I suggested to the producer to cut through the Web API in Edge. This worked, and he continued in this way until a break where he could close and re-open vMix. This returned vMix to a fully working state.
Have any of you tried this?
It appears that the support team haven't heard about this issue yet.
ask
#2 Posted : Saturday, September 7, 2019 8:59:37 AM(UTC)
ask
When these kinds of behaviours occur I check for queued windows updates. Even if you have paused the updates, they seem to make the PC behave sluggishly and/or unexpectedly. Run the update and usually all is well.
niemi
#3 Posted : Thursday, September 12, 2019 12:19:48 AM(UTC)
niemi
Thanks. However, I am using the ability in vMix to "Disable Windows Update when vMix is running" so it is unlikely that updates were causing this.
Guest (4)
