aircooled76@gmail.com
#1 Posted : Wednesday, September 4, 2019 5:36:49 PM(UTC)
My "simple but impossible mission" is to play the last two events remotely via the Web API.
Using the ReplayPlayEventsByID or ReplayPlayEventsByIDTo Output I can play multiple events by sending the command:
Code:
x.x.x.x:8088/api/?Function=ReplayPlayEventsByIdToOutput&Value=000,002
However, there is no way to get the information via the API of what the last event ID was (that I can find) So this is not usefull.
I thought a relatively easy fix would be to enable the ReplayPlayEvent and ReplayPlayEventToOutput to take more than one value.
x.x.x.x:8088/api/?Function=ReplayPlayEventToOutput&Value=0,1
Vola... last two events played!
This should not break existing functionality and hopefully is fairly easy to implement. Or we could add a "PlayLastEvents" and "PlayLastEventsToOutput" shortcut.
(or we could add info on the last event ID to the web API)
Code:
<replay live="True" recording="True" events="1" cameraA="1" cameraB="1" speed="1">
<timecode>2019-09-04T08:50:03.589</timecode><lasteventid>003</lasteventid>
</replay>
thanks 1 user thanked aircooled76@gmail.com for this useful post.
Ario on 11/19/2019(UTC)
Ario
#2 Posted : Tuesday, November 19, 2019 6:57:50 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Thanks for your help & this good solution.
I warmly support your request to have a functionality like this added to vMix,
as explained in
https://forums.vmix.com/...er-of-events-to-play-out
especially with the possibility to play latest-to-oldest.
Let's say during a basketball game the sweat needs to be wiped from the floor. Play stops. Will this give time for 1, 2, 3, .... replays?
No one knows.
So let's just start with the latest event (most recent), the one no viewer has seen played back yet, and move back in time from there.
Replays can be kept running until live play continues (or until all replay events have been played back, if replay Loop is off).
Thanks again.
Barney Box Lane
#3 Posted : Tuesday, November 19, 2019 11:30:15 PM(UTC)
Barney Box Lane
+1 play last events with a value you can input to the value section
thanks 1 user thanked Barney Box Lane for this useful post.
Ario on 3/13/2025(UTC)
#4 Posted : Saturday, April 4, 2020 7:17:30 PM(UTC)
Just bumping this thread!
Would really really really LOVE a solution to this.
#5 Posted : Saturday, May 16, 2020 8:03:59 PM(UTC)
I will sing a Karaoke song of Martin's request and change the worlds to say awesome things about vMix... If this feature is added :)
