Virtual Input with Overlayers
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Hallo, Question is this Possible
I have 4 different inputs from GT Designe I great a Virtual input with all 4 animation (Multivew)
now it shows me all 4 Animation but i want see the animation only when i start the overlay.
Sorry again for my amazing explanation in english ;)
That's not how it works !
a multiview as overlay doesn't trigger title animations why not combine your 4 titles as one and use as overlay (as intended) ?
The problem is that I have at the moment 4 titles at the end it’s over 20. I searching a solution how I can send out each of them if they start over NDI. But I think for this I must work with a separat system and software :(
Quote:The problem is that I have at the moment 4 titles at the end it’s over 20 they are making little title babies? don't put them together in a multiview then ;-) you are going from 4 titles in a multiviews wanting to animate them when overlayed as one that will become 20 that you want to send out comming in as a ndi input ?? do your titles look the same but have different content? they come in as ndi from where ? and where do you want to send them to ? Sorry trying to visualize what your intention is , maybe someone else will , but i am not seeing it
Ok from the beginning. I have 5-10 vmix systems running for videoreplay and also live streaming. Inside of 1system are a lot of different Titel and styles. Scoreboard, player informations 1-2-3, round Information for each round, commercials, statistics afther a match.
All informations are in vmix and they show up now automatic. The systems are for the replay but I send also out 1 stream from each of them with the Titels inside.
Now I want build 1 mainstream pc with this pc I have all camaras from each court that I can switch between the 5-10 courts.
But now I need also the Titel informations from this courts tho the main stream.
My Idee are now to take the Titels from the courts the main streaming pc.
The other solution is to build a separate pc for the Titels but this is not my favorite Idee if all information in vmix
What about having your titles on the mainstream also and focus on getting the data part displayed into it depending on the camera you selected in your mainstream ?
I think it would be easyer to have some script checking the camera / video your are currently using and base the rest on that as if it was one of the other individual vMix systems
