Triggers - Output - Stop Multicorder
Joined: 8/13/2019(UTC) Posts: 3   Location: Perth Thanks: 1 times
Hi We are running a trial version to test a feature. I'm able to get the Multicorder to Start using a -6db Trigger. BUT cannot get it to Stop... From the picture attached... which command would you use next to Stop the Multicorder. Note:I tried the OnAudioMeter6DB with StartStopMulticorder but that just looped... Willing to try all options. - Bevvo Perth, AU vMix STOP.png (1,201kb) downloaded 4 time(s).
it wasnt possible... we used a USB joystick game controller board and used BUTTON DOWN and BUTTON UP as a trigger.
works fine.
