Pardon The Interruption Template
I am starting a new show and would love to find some kind of template like the ESPN Show Pardon the Interruption. Anyone know of anything similar to this, or if something like this can be created in vMix?
[img=https://images.app.goo.gl/DtTZY9AzYxe4h6Jc9]PTI Screenshot[/img]
Joined: 8/2/2013(UTC) Posts: 1,111   Location: Fairhope, Alabama USA Thanks: 604 times Was thanked: 205 time(s) in 171 post(s)
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
@danspada Need to use the create link icon and not the Insert Image Icon to display the link to the image. Here is the proper link. PTI Screenshot
Joined: 7/14/2017(UTC) Posts: 100   Location: South Florida Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
I have created various videos that do just that. Here is the process I use. 1) Find a suitable image or video. ( I use a video of planes taking off and landing) 2) If you are using a video, place it in a video editor (Filmora or something like it, if using an image create titles with an image editor, I use Iranview). Add whatever text you want and compile the video, or save the image. 3) Use the video or image as an input in VMIX and loop if you are using a video. This will run continuously until you stop the looping process. Hope this helps.
