Keneddy
#1 Posted : Friday, July 26, 2019 11:45:16 PM(UTC)
Keneddy
Brazil
Hello everyone.
Since I bought Vmix I can't get a good online transmission. The image has some stops, quick framer freezes, like lags and I don't know how to set it up. My camera is a Logitech C920 Pro Full HD 1080p
SportsNetUSA.net
#2 Posted : Saturday, July 27, 2019 8:15:36 AM(UTC)
SportsNetUSA.net
Check your Internet speed. What is the Upload speed?
Check your streaming settings. Do you have enough upload speed for those settings?
If you are streaming at 1080P, try dropping down to 720p and see if that helps.
Use the streaming presets built into vMix first, then experiment with different settings after you've solved this problem.
