vMix Call
Problem vMix call Kbps
Hello
I have detected a vMix Call issue in vMix 22.0.0.66. Receive only between 50 and 400 Kbps. The picture quality is very bad. On a second PC I still have vMix 22.0.0.60 installed. I get on average between 1500 - 2000 Kbps. I suspect a bug in vMix 22.0.0.66. Has anyone else made this determination?
Greeting
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
If you are using a browser to connect, the browser determines the bitrate based on network conditions and we have no control over that. Also, there have been no changes to vMix Call in vMix 22, it is the same as in 21, so I would guess the reason above is the cause.
Martin vMix
Hello Martin,
Thanks for the answer. Funny, back to 22.0.0.60, identical browser, same network, same location. Get back 1500 - 2000 Kbps. Again update to 20.0.0.66. No change location, network or browser. Get only between 50 and 500 Kbps. Funny.
Greeting
Edit: Video Out I get 2000 Kbps. The video is displayed on the external smartphone without juddering and good video quality. The problem is Video In. Since I get maximum about 400 Kbps and a bad bit rate and resolution.
vMix Call
