Selecting input number in new update
Thanks: 8 times Was thanked: 12 time(s) in 9 post(s)
I see it is possible to select input number when creating new inputs in the new .66 update.
I think this has been brought up before, but is there any way to force a higher number than the number of inputs?
It would be useful to be able to for example lock a lower thirds GT layer to say input 99 if you use keyboard shortcuts to cycle through the different presets.
The way it is today, if you add a new camera input and the title layer moves up to a new number, your keyboard shortcuts will stop working since they are connected to the input number.
Quote:keyboard shortcuts will stop working since they are connected to the input number. Are they ? unless you checked assign the shortcut to input number
Originally Posted by: doggy  Quote:keyboard shortcuts will stop working since they are connected to the input number. Are they ? unless you checked assign the shortcut to input number I seem to remember that it didn't work even with assign to input unchecked, but it seems to work now. However it will not work if you make a new project, or if you want a new lower thirds preset. If you could just say that input 99 was your lower thirds input, you could make sure the keyboard shortcuts would work regardless of the project. It would allow you to make it more similar to traditional systems where you have ddr/gfx/buffers ect that is completely separate for your regular inputs.
