GT
Edit gtzip file
Hi, it is possible to edit a gtzip in any way with an editor.
I can unpack a gtzip file with 7zip and get an folder with some xml files and image files. The document.xml inside contains all the object data that I can edit by an editor. But I don't know how I can repack the folder with the modified document.xml back to a valid gtzip file.
Thanks Alex
Originally Posted by: doggy  GT title designer ? Ok, I understand now how it works. Just save the project as gtxml file. I overlooked that possibility. Thanks for the thought-provoking impuls. Alex
GT
Edit gtzip file
