virtual set Under it colour key?
Why can't I use?Is it because it is not a single input source? Or become the input source for replication
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ edgerobbie I provided the following answer here: https://forums.vmix.com/...set-colour-key#post67176Can you clarify what you want to do? Essentially, a Virtual Set Input is blank or transparent with layers applied to it, so there is nothing to colour key from the original Input or base layer therein. Background images or sets are basically added as layers in the config file and you generally do not have access to them, but they are still layers on the Input. If there is something that you want to key out on those images, you would have to add it as an Input in vMix first and then use the colour key on the actual Input and then add it as a layer to your set, just like removing the Green screen of the Talent layer.
I hope that makes sense.Ice
Thank you for your reply.I want to synthesize other videos in the GT title.I don't want to use imagesequence.Is there a way to make it a composite output and then take it as an input source?
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Virtual set or GT title ? same case of different ?
 capture - 18 Qi Yue 2019 - 02-23-28 Xia Wu .mov (2,064kb) downloaded 10 time(s).I want to do this title.Adjusting parameters is cumbersome...
Originally Posted by: edgerobbie   capture - 18 Qi Yue 2019 - 02-23-28 Xia Wu .mov (2,064kb) downloaded 10 time(s).I want to do this title.Adjusting parameters is cumbersome... There are different ways to achieve this but probably all to cumbersome anyways
