Joined: 7/13/2019(UTC) Posts: 1  Location: Mississauga
I am in the testing stages right now. Here's my setup:
2X canon HF R800 Camcorder 2X Camlink 4K USB Capture Processor: Intel Xeon E5-2630 V2@ 2.60 GHz 32 GB DDR3 EC Ram Nvidia Quadro K2200 - 4GB GDDR5 300GB SAS Driver 15000 RPM 500GB WD 7200 RPM 3TB USB3 WD 7200RPM USB3 Bus all through
When I add the cameras to vmix. First camera works great. Silky smooth video @ 1920x1080 59.94p. 2nd camera however always suffers from jerky video. Resolution on the cameras is the exact same. connections are fine. Video Format is YUY2. Someone help asap. I have a big project coming up in a week and want to get this running smoothly.
Thanks AJ
My guess is that you are overloading the USB bus. Put the camlinks on separate ones.
 1 user thanked ask for this useful post.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
camlinks on the usb with the blue bit inside so it's powered or fast maybe? I haven't had fully smooth footage through an elgato yet to the point is have it as a main camera but there's so many things you can't really go off that unless loads of people are experiencing that
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 319 times Was thanked: 263 time(s) in 233 post(s)
Camlink does not do any frame rate conversion or scaling. Nor does it compress the video over the USB link. It only delivers YUY2 uncompressed.
A single 1080p60 stream of YUY2 uncompressed requires 3 Gbps.
A USB 3.0 bus theoretically delivers 5 Gbps. In practice, it delivers something substantially less. Think 4 Gbps.
So you cannot use two Camlinks, with 1080p60 sources, on one USB 3.0 bus. If you try this you'll find that only one works.
To deliver 4k30, the device uses NV12 encoding. It's still uncompressed, but the 4:1:0 color sampling reduces the bandwidth required just enough to fit across a USB 3.0 link. The Logitech Brio 4K webcam uses NV12 as well.
