vMix scripting - How to loop a script?
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
Hello. Recently found out about scripting capabilities in vMix. I am planning to use it to shuffle ads automatically that are inserted in multiview of an input. So far I am using WEB Scripting and was able to change multiview inputs, but is it possible: 1) to loop a script? 2) to use IF statements? 3) to run the script if a certain input became active?
Thanks!
1) yes 2) yes 3) would guess so by checking the state on the input or the active input number from the /API xml
Originally Posted by: doggy  1) yes 2) yes 3) would guess so by checking the state on the input from the /API xml Please tell me how would I do 1-2. Didn't find any info in Documentation.
vMix Scripting supports the powerful and easy to understand VB.NET language when writing your script.
for example Code:Do While true
if .....
end if
Loop
