bronxu
#1 Posted : Tuesday, July 9, 2019 9:19:38 PM(UTC)
bronxu
Poland
I need to do such a multiview
can I do it in vmix for the needs of implementation?
More specifically, I need to cut the corner of 2 sources
[img=https://ibb.co/47sWqmD]look[/img]
Help Please Someone ?
#2 Posted : Tuesday, July 9, 2019 10:38:54 PM(UTC)
link to image doesn't work
#3 Posted : Wednesday, July 10, 2019 12:36:31 AM(UTC)
@ bronxu
No, vMix is not able to crop diagonally as per your graphic:
Peter1000
#4 Posted : Wednesday, July 10, 2019 2:38:20 AM(UTC)
Peter1000
Switzerland
Was thanked: 82 time(s) in 62 post(s)
you can do this with two masks, input 1 & 2, and a virtual input, as in the example.
the mask is a simple png file with black as transparant and white as visible.
In your live input 1, in the example rasen.jpg, you go to settings, colour key and in the bottom you see Key/Fill Input, there you select the first mask, 1.jpg
In your live input 2, in the example bilder(3).jpg you do the same with the second mask, 2.jpg
create a virtual input from your live input 1
go to the virtual input 1, settings, multiview, on 1 select the live input 2, on 2 select your graphics
thats it.
Vertical Split.PNG (993kb) downloaded 5 time(s).
thanks 1 user thanked Peter1000 for this useful post.
RichDanby on 7/10/2019(UTC)
Peter1000
#5 Posted : Wednesday, July 10, 2019 3:04:06 AM(UTC)
Peter1000
Switzerland
i assume that you want to use your two live inputs also fullscreen, then you have to make two downscaled virtual inputs of your sources and you would need other key files for them.
And with either fullscreen Live Input as preview selected, you can even zoom out to fullscreen out of the composition with merge.
bronxu
#6 Posted : Wednesday, July 10, 2019 3:19:33 AM(UTC)
bronxu
Poland
Thank you all for your help, but I managed to get it myself on the luma key
let it stay for posterity :)
Guest (4)
