cutter07
#1 Posted : Monday, November 4, 2013 4:56:56 PM(UTC)
cutter07
With Version 11 of Desktop Capture we have trouble to get an instant update for all "Desktop Capture" Inputs. For example we use two "Desktop Capture" Inputs from the same computer / ip adress, one with colour key and one without (both inputs uses the second display, X0 Y0 W1920 H1200). If something change on the captured computer mostly only the first input are updated.
vMix Version: 11.0.0.41 x64
#2 Posted : Monday, November 4, 2013 10:49:19 PM(UTC)
Instead of adding desktop capture twice. Add the first one and then go to Input Settings and click Create Virtual Input.
cutter07
#3 Posted : Tuesday, November 5, 2013 12:59:19 PM(UTC)
cutter07
That solved it, thanx
