Troviss
#1 Posted : Wednesday, October 30, 2013 2:55:31 AM(UTC)
Troviss
I have installed vMix (60 days test) on my PC, but tryed install it on a laptop to, but it didn´t work. I tryed many times and I even tryed to get a new registration key, but ut didn´t work.
Now I have lost the key number and can´t find it. How can I get a new registration key, so I can install vMix on my laptop?
Troviss
#2 Posted : Wednesday, October 30, 2013 10:08:53 AM(UTC)
Hi Troviss,
If you are using the 60 day trial select the trial option and use your email address when installing on the laptop.
The trial keys are not designed to be used more than once.
Troviss
#3 Posted : Thursday, October 31, 2013 11:00:21 AM(UTC)
Troviss
I installed vmix on my friend's laptop that I can borrow to test how it works. After installation, I have to choose one of three options. I choose it at the bottom which is for registration for a fully functional 60 day trial. But that's not work how I try. I get the following message: Exception from HESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILUR))
#4 Posted : Thursday, October 31, 2013 11:19:34 AM(UTC)
Unfortunately that error means a component in Windows is corrupt.
You can try fixing this by making sure all the latest windows updates and drivers are installed.
Troviss
#5 Posted : Saturday, November 2, 2013 8:38:35 AM(UTC)
Troviss
ok I do like this I uninstall Windows Vista because it gives me some problems and I will install Windows 7 insted. But what version of vMix is included in the trial? Is it a fully working HD Pro?
Damn2Good4U
#6 Posted : Saturday, November 2, 2013 9:11:25 AM(UTC)
Damn2Good4U
YES, its the Fully working HD Pro version...
