Milos
#1 Posted: : Monday, October 28, 2013 5:36:24 PM(UTC)
Milos
Hello Martin,
Can you add support for HTTP stream as input (source)?
Thanks!
ask
#2 Posted : Monday, October 28, 2013 11:09:41 PM(UTC)
ask
This is possible using the desktop capture program.
Milos
#3 Posted : Thursday, October 31, 2013 2:09:54 PM(UTC)
Milos
Yes, but this is not native support for HTTP stream.
nprasan
#4 Posted : Tuesday, November 5, 2013 6:40:15 PM(UTC)
nprasan
Native support for HTTP streams will be quite a useful feature.
It will allow the use of smartphone cameras as inputs as there are apps available on all leading mobile operating systems to stream the phone camera as an MJPEG stream over HTTP. The support for camera RTSP streams is minimal or absent in mobile platforms. Further, a lot of IP cameras also support HTTP streaming.
Please try to include support for this feature in the next release.
Sextronic
#5 Posted : Saturday, April 4, 2015 4:42:48 AM(UTC)
Sextronic
Theres a neat workaround, i use vlc to restream http input into rtsp on the same PC. Works flawlessly. Creates virtually no cpu load, considering disabled transcode option.
Though,
I second that.
pampurio97
#6 Posted : Tuesday, September 29, 2015 9:13:11 AM(UTC)
pampurio97
Anything new about this? It's been 2 years and no words from vMix. But I find this a really important feature.
wwdv
#7 Posted : Saturday, December 5, 2015 12:29:03 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
+1
What Sony camera's concerns:
RTSP has 1 second latency and you need a buffer of at least 500ms to avoid freezes, the Sony http viewer is almost realtime.
charlie
#8 Posted : Thursday, December 10, 2015 5:52:37 AM(UTC)
charlie
+1
I need too this option
mavik
#9 Posted : Saturday, September 22, 2018 2:47:05 PM(UTC)
mavik
Was thanked: 186 time(s) in 166 post(s)
+1
#10 Posted : Saturday, September 22, 2018 3:49:43 PM(UTC)
vMix support http streaming protocols as an input. Just use VLC for vMix addon
https://www.vmix.com/kno.../installing-vlc-for-vmix
Guillaume
mavik
#11 Posted : Saturday, September 22, 2018 4:52:58 PM(UTC)
mavik
Thanks Guillaume. But how do I use it.
#12 Posted : Saturday, September 22, 2018 5:21:36 PM(UTC)
Add a stream input, select vlc in the list and write the stream address
JW
#13 Posted : Saturday, September 22, 2018 5:51:41 PM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
You can also use the free Alax DirectShow filter, it has (in my case) lower latency.
The added camera's will directly show up in vMix under camera inputs.
See this link.
#14 Posted : Sunday, September 23, 2018 2:23:23 AM(UTC)
Another solution based on Newtek NDI plugin for VLC
> play the http feed in VLC, the plugin turns it into a NDI source that you can add to vMix
mavik
#15 Posted : Monday, September 24, 2018 1:48:00 PM(UTC)
mavik
Thanks a lot for the many replies. I'm able to ingest my HLS stream now.
Barney Box Lane
#16 Posted : Monday, October 1, 2018 4:44:26 AM(UTC)
Barney Box Lane
+1 we're using restream but paying to have a stream redistributed and not using half of what we're paying for (it's awesome though)
Guest (4)
