David Fleischer
#1 Posted : Saturday, October 26, 2013 11:06:55 AM(UTC)
David Fleischer
Can I run more sessions on same PC?
My challenge is that I need to run up to 4 streams at the same time, so the question is will I need 4 PC´s or can I run 4 sessions on same?
Egriswold
#2 Posted : Saturday, October 26, 2013 2:17:38 PM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
Are all the streams the same type i.e. flash ?
if not, multiple encoding programs can grab the single vMix hook
Jup
#3 Posted : Saturday, October 26, 2013 5:29:30 PM(UTC)
Jup
I did a quick experiment and was able to get 2 instances of vMix running:
I used 2 different versions, and installed to "/progfiles/vmix1" and "/progfiles/vmix2" respectively (also pay attention to shortcut and start menu names)
If your screen resolutions is high enough and monitor large enough, and your system is high end, why not experiment yourself with the trial versions and see if it does what you want it to?
thanks 1 user thanked Jup for this useful post.
David Fleischer on 10/28/2013(UTC)
