burie
#1 Posted : Tuesday, April 23, 2019 1:43:16 AM(UTC)
burie
Germany
I tried to config a JSON dataSurce, but the message is unexpected character "<"
The JSON comes out of a PHP Script.
When I let the script write the JSON in a File and open that in a editor, there is no such char.
I have a screenshot available...
Where is the solution?
stigaard
#2 Posted : Tuesday, April 23, 2019 2:34:44 AM(UTC)
stigaard
Denmark
Wrap your output into an array. E.g. [...]
burie
#3 Posted : Tuesday, April 23, 2019 2:57:14 AM(UTC)
burie
Germany
I do not quite understand what that helps me.
EDIT...
For understanding... what you see in the screenshot is not the source, it is the result. It is the result of result of a website parsing.
calamityjane
#4 Posted : Friday, April 26, 2019 12:26:32 PM(UTC)
calamityjane
I am also looking for help with JSON as a datasource.
A web query of the JSON source looks like this ( well a lot more data but in this format):
{"SiteKit":{"Parameters":{"feed":"modulekit","view":"roster","key":"xxxxxxxxxxxx","fmt":"json","client_code":"cchl","lang":"en","season_id":0,"team_id":"7","lang_id":1,"league_id":"1"},"Roster":[{"id":"5902","person_id":"6732","active":"1","first_name":"Antoine","last_name":"Bourdeau","phonetic_name":"","display_name":"","shoots":"L","catches":"L","hometown":"Montreal, QC","homeprov":"","homecntry":"Canada","homeplace":"Montreal, QC, Canada","birthtown":"Montreal, QC","birthprov":"","birthcntry":"Canada","birthplace":"Montreal, QC, ","height":"6-0","weight":"193","height_hyphenated":"6-0","hidden":"0","current_team":"","player_id":"5902","status":"","birthdate":"2000-02-14","birthdate_year":"'00","rawbirthdate":"2000-02-14","latest_team_id":"7","tp_jersey_number":"1","rookie":"0","position_id":"7","position":"G","nhlteam":"","playerId":"5902","isRookie":"&nbsp;","h":"6-0","w":"193","draftinfo":[],"name":"Antoine Bourdeau","flags":[],"player_image":"https:\/\/assets.leaguestat.com\/cchl\/240x240\/5902.jpg"},{"id":"5899","person_id":"6729","active":"1","first_name":"Mathieu","last_name":"Wuth","phonetic_name":"","display_name":"","shoots":"R","hometown":"Broomfield, CO","homeprov":"","homecntry":"USA","homeplace":"Broomfield, CO, USA","birthtown":"Broomfield, CO","birthprov":"","birthcntry":"USA","birthplace":"Broomfield, CO, ","height":"6-2","weight":"174","height_hyphenated":"6-2","hidden":"0","current_team":"","player_id":"5899","status":"","birthdate":"2000-06-01","birthdate_year":"'00","rawbirthdate":"2000-06-01","latest_team_id":"7","tp_jersey_number":"5","rookie":"0","position_id":"1","position":"D","nhlteam":"","playerId":"5899","isRookie":"&nbsp;","h":"6-2","w":"174","draftinfo":[],"name":"Mathieu Wuth","flags":[],"player_image":false},
29 more player sets of data then finishes
{"id":"18206","first_name":"Brooks","last_name":"Taylor","name":"Brooks Taylor","coach_id":"490","role_id":"16","role":"Equipment Manager","person_id":"6069","hometown":"","homeprov":"","jersey_number":"0","start_date":"2019-03-16","end_date":"","is_admin":"0"}]],"Copyright":{"required_copyright":"Official statistics provided by Leaguestat","required_link":"http:\/\/leaguestat.com","powered_by":"Powered by HockeyTech.com","powered_by_url":"http:\/\/hockeytech.com"}}}
When vMIX tries to read this data source it generates the message:
ERROR: A column named "id" already belongs to this Data Table
Is my data source corrupted ? or .......
Whit
burie
#5 Posted : Friday, April 26, 2019 2:32:40 PM(UTC)
burie
Germany
i could imagine that vmix has a problem with chars like "[" on the wrong or unlucky position :-)
BUT why didn't You create your own topic?
chrisg101
#6 Posted : Wednesday, June 26, 2019 10:39:14 PM(UTC)
chrisg101
Hi Burie - I was having a similar issue "Encountered unexpected character '<'" - when adding a JSON source.
Did the suggestion fix your issue?
#7 Posted : Thursday, June 27, 2019 2:18:24 AM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
In the original case posted in this thread, the php file was being loaded directly from disk, so it didn't have any JSON inside it, only code.
If they loaded it from a web site setup to server PHP correctly, it would have worked correctly.
burie
#8 Posted : Thursday, June 27, 2019 4:28:47 AM(UTC)
burie
Germany
DAMN you're right. My fault. I have a apache running behind, but called the PHP File the wrong way. E:\_Data is the localhost folder.
I will try it ASAP, I'm not near this PC.
On another thread I got a good hint for a solution with PHP and XML. Until the end I had used to the output return (), how to do that with PHP functions. But since I use echo for the output instead, this works. Maybe that's an approach as well.
