Joined: 10/1/2016(UTC) Posts: 117  Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
So have a strange one...maybe some community members can share some tips/settings that work for them. Have a a client that want’s us to stream to their WIX page. Did a test last week with a 1hr stream with recommended WIX settings in vMix - went back today to run a test and vmix just drops connection after a few seconds. Downloaded OBS and and used NDI plugin to get data out of vmix into OBS. Used WIX default OBS settings and it streamed fine. Did three 20 to 30 minutes tests with no issues.
Tested one more time with a vMix stream to WIX to male sure I am not going crazy, but same results it just drops connection after a few seconds.
Anyone have vMix setting that is streaming directly to WIX?
Joined: 4/23/2017(UTC) Posts: 1,466  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Does Wix have/offer a streaming Server for their websites? Usually you connect to a streaming server or service and embed the player into wix. What settings have you streamed with?
Thanks... in the end we are just using vmix NDI output into OBS to stream as vMix just won’t hold or make a connection with WIX live streaming servers. Changing vmix streaming settings did not seem to help.
