christianm
#1 Posted : Tuesday, June 18, 2019 6:45:46 PM(UTC)
christianm
Loving the virtual sets however every so often my talent is in the wrong place every so slightly and I have been unable to find a way to make changes on the fly. In other inputs such as images or static cameras the virtual PTZ controls work well however they do not function from within a virtual set. My suggestion is as follows.
- Enable Virtual pan-tilt-zoom controls in the virtual set on the fly (not only preset shots) allowing changes via standard vmix PTZ controls such as keyboard shortcuts or external controller.
#2 Posted : Tuesday, June 18, 2019 7:28:35 PM(UTC)
PTZ control on the input (talent) , not on/in the virtual set
christianm
#3 Posted : Wednesday, June 19, 2019 9:43:43 AM(UTC)
christianm
Yes this works however using this approach the changes to the PTZ controls on the input (talent) have no effect on the other parts of the virtual set throwing it all out. The function I am after is to use the V-PTZ controls located in the settings of the virtual set (but currently do nothing) to apply to the whole set and its layers exactly the same way the 4 presets work.
