Feature Requests
Selecting more than one element to change Data Options in GT Designer
Joined: 6/20/2015(UTC) Posts: 15 Location: Baton Rouge
Thanks: 22 times Was thanked: 3 time(s) in 3 post(s)
Now that the "Show Visible Toggle" option has been created alongside the others in the Data section in GT Designer it might be worthwhile to be able to make those changes when more than one element has been selected. That way you don't have select each element one-by-one in order to change the Data options.
Tony Lightfoot TWSBC
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Feature Requests
