GT
Ticker with more dataSource Fils
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Hallo, i hope someone have a idea how i can solve this
I want make a Ticker with data file from the Data Source csv, but i need more fils from the Data Source
Exempel
Event Name / Match (File from Data Source) / Class ( File from Data Source) / Category ( File from Data Source)
is there any solution how i can add more than 1 datasource information to a ticker ?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
not possible
all i can think if (within vMix) is to create a title containing separate textboxes aligned one after the other and animate them continuously looking like a ticker Definitely possible with XAML but not sure about GT title
Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi You may be able to do this, if I have you request correct using Google Sheets. Create a sheet as shown  Capture1.PNG (30kb) downloaded 5 time(s).Add GT Title ticker to vMix and go to the DataSource Manager. Add the details for your sheet.  Capture2.PNG (12kb) downloaded 1 time(s).Then go back to your Data Source panel and set the Column, in my case it is 6, which is the concatenation column  Capture3.PNG (10kb) downloaded 3 time(s).Then vary either the length of Manager Delay in seconds and the GT scroll speed etc to get your outcome. Make sure the Manager Auto Next is on  Capture4.PNG (2kb) downloaded 0 time(s).You could add another concatenation column that encapsulates all of the data. Is this what you require? Ash Originally Posted by: bgbenni  Hallo, i hope someone have a idea how i can solve this
Exempel
 1 user thanked Ash for this useful post.
proven it can be done with a basic xaml title without manipulating the datasource ,was posted on a facebook page
As an aside you can add separate text fields as doggy suggest and just assign the individual cell data. Then some animation.. Example animation
GT
