Joined: 9/26/2014(UTC) Posts: 107  Location: Canada Thanks: 39 times Was thanked: 5 time(s) in 5 post(s)
Hi
I am desperately trying to restore/find the shortcuts I had used awhile back. Probably a few versions ago, maybe as far back as V18?
I did read the GLOBAL shortcuts are stored in the settings and the LOCAL shortcuts in the presets.
When I load the presets that they would have been , they re not there.
Is it possible the settings do not get carried forward when you update a version ? Is there a way to load say Version 18 and see if the shortcuts are in the settings there?
Any suggestions or ... if there is any hope of recovering these shortcuts?
Whit
Found a old config file and they were there. Thanks
