 Joined: 5/27/2019(UTC) Posts: 2  Location: Asturias |
                Hello, the company where I work has an old version of vmix (21), my question is whether it is possible to update the FFmpeg decoders that the program has incorporated into the latest version that is on the internet.Greetings to all.
 Thanks: 6 timesWas thanked: 9 time(s) in 5 post(s)
                I think the ffmpeg binarues are somewhere inside the vmix installed directory. Try searching for file ffmpeg.exe .
 Not sure if replacing them will work, so please back up originals.
 Joined: 5/27/2019(UTC) Posts: 2  Location: Asturias |  |
