5 Pages«<2345>
km_rtf
#61 Posted : Thursday, November 29, 2018 11:40:02 PM(UTC)
km_rtf
Germany
Yes, i need to use a font without linear character spacing, so i dont want to use use right alignment because the text "bounces" around every second.
It doesnt matter if i have a leading zero or just a space in front of the time.
Alex
If somebody is interested what we stream: (Game was last Saturday without OCR)
http://sportdeutschland....etten-vs-hsc-2000-coburg
dundurs
#62 Posted : Friday, November 30, 2018 4:12:03 AM(UTC)
dundurs
Was thanked: 45 time(s) in 22 post(s)
Alex,
We will implement padding.
I will let you know.
Arturs
dundurs
#63 Posted : Monday, December 10, 2018 2:53:55 AM(UTC)
dundurs
I wanted to let you know that we created several video tutorials that might come in handy.
Here is the playlist of all the tutorials:
https://www.youtube.com/...YsTC0NoVAHLOXEMrIz2gwuid
And here is a tutorial on how to send data to vMix API:
Enjoy,
Arturs
thanks 3 users thanked dundurs for this useful post.
ask on 12/10/2018(UTC), guztavo on 12/15/2018(UTC), elvis55 on 1/3/2019(UTC)
dundurs
#64 Posted : Sunday, December 30, 2018 10:19:11 PM(UTC)
dundurs
We have introduced "Padded" option for vMiX API output.
Please update to the latest version and let me know if this works for you.
Arturs
P.S. Also we have had some other updates: http://wiki.scoreboard-ocr.com/changelog
Ikovacevic
#65 Posted : Tuesday, February 5, 2019 5:26:02 PM(UTC)
Ikovacevic
Very good software with good opportunities, but....from my perspective it is not ready for production. I have used it for basketball live stream, and this is my experiences:
- problem exists when time is less than minute, it can not recognise tenths and shows total wrong data
- sometimes my cpu goes high and picture starts to interrupt
- after 2 hours of using OCR software just crashes. After that my blackmagic card, where camera for semafor is connected stops working and I have lost my dat
dundurs
#66 Posted : Tuesday, February 5, 2019 5:29:36 PM(UTC)
dundurs
1. Did you set the correct time validation format "Time (mm:ss, ss.d)"? http://wiki.scoreboard-ocr.com/format
2. We are still working on getting the CPU usage down, I will let you know when there is an update
3. Which BMD card did you use at what resolution? I will try to replicate the crash
Arturs
Ikovacevic
#67 Posted : Wednesday, February 6, 2019 5:08:17 PM(UTC)
Ikovacevic
1. Yes, I use Time validation (mm:ss)
3. I use BMD card Intensity Shuttle for USB 3.0, resolution is 720P
Here you can find video I made 10 days ago. At end of every quarter it is visible when in the last minute date gone wrong. At end of game MBD card crashed and I lost all data (time and result). After that i have written in result maunaly.
Maybe this also can be usefully, I had two time when BMD crashed in two different games. First in december of last year, and second time was last week.
OCR worked perfectly until november of last year, after that period and many updates I have problem with using it. In december I saw that OCR in the middle of game, not only in the last minute of quarter period started showing wrong time data without any visible reason.
Thank you for helping me :)
dundurs
#68 Posted : Thursday, February 7, 2019 3:46:32 AM(UTC)
dundurs
1. You should use "Time (mm:ss, ss.d)" instead of "Time (mm:ss)". Which one did you use ?
3. I will try to get Shuttle for USB3 and play around with it
curtismacd31
#69 Posted : Thursday, February 7, 2019 4:40:17 AM(UTC)
curtismacd31
@Ikovacevic
The USB3 intensity shuttle is a very unreliable device. I have used 3 different units and all 3 were not reliable on any PC. If you're using a laptop try something from Magewell or AJA, if you have a desktop and a spare PCIe slot try a BMD Mini Recorder or Decklink SDI 4K.
Just my thoughts
Ikovacevic
#70 Posted : Wednesday, February 13, 2019 9:14:46 PM(UTC)
Ikovacevic
Sorry for delay,
Thank you for your advices. I use desktop PC and I have PCI MBD Mini recorder card so next time i am gonna try to use it like replacement for USB 3.0 Intensity shuttle.
Best regards
Le-bo2d9
#71 Posted : Sunday, May 26, 2019 1:26:00 AM(UTC)
Le-bo2d9
Hi Dundurs,
How do you update the fouls images?
Kind Regards
Koen
dundurs
#72 Posted : Sunday, August 18, 2019 12:23:06 AM(UTC)
dundurs
Originally Posted by: Le-bo2d9 Go to Quoted Post
Hi Dundurs,
Kind Regards
Koen
Hi Koen,
A very simple way would be to create images in your graphics for each number of fouls. For example, if there are 3 fouls for team A, you could display c:/team_a/3.png
This is how we do it in our graphics.
Arturs
Le-bo2d9
#73 Posted : Sunday, August 18, 2019 1:46:49 AM(UTC)
Le-bo2d9
Hi Dundurs,
I had mangage the updates of the foul images bij scripting
In the link below you can find one of our streams.
Spain vs. Canada
The only ploblem we had was that during a time out there was a countdown clock on the sceen and the seconds where on the same plase as the fouls number. So during a time out the foul flags where changing...
I need to adapt me scripting to prevent these changes
dundurs
#74 Posted : Saturday, August 24, 2019 1:36:25 AM(UTC)
dundurs
We just published an update that should hopefully solve the vMix render times problem when using vMix API to send data from Scoreboard OCR to vMix.
Basically we were sending a lot of data and now we considerably decreased the amount.
You can update right from the application or install from scratch: http://wiki.scoreboard-ocr.com/start
Let me know if the problem has been solved,
Arturs
dundurs
#75 Posted : Thursday, September 5, 2019 7:59:24 PM(UTC)
dundurs
Another very important update just published, which should deal with NDI crashes:
Updating to the latest version is recommended.
Arturs
dundurs
#76 Posted : Tuesday, September 10, 2019 5:46:30 AM(UTC)
dundurs
Heads up - the render spike issue has not been solved, we are still working on it.
As an alternative, I did a test with Scoreboard OCR XML output + vMix reading file every 100ms and it works fine.
I will let you know as soon as problem is fixed.
Arturs
dundurs
#77 Posted : Sunday, September 15, 2019 3:20:08 AM(UTC)
dundurs
Happy to report, that the problem has been solved: https://forums.vmix.com/...t18200-vMix-22-Changelog
Please update vMix to version 22.0.0.68
Arturs
dundurs
#78 Posted : Friday, September 27, 2019 4:05:43 AM(UTC)
dundurs
We just released an update - now you can use spaces in field names (helps with vMix GT titles, that have spaces by default).
And few more improvements: http://scoreboard-ocr.com/changelog
Arturs
thanks 1 user thanked dundurs for this useful post.
ask on 9/27/2019(UTC)
chrworks
#79 Posted : Tuesday, October 8, 2019 1:09:34 AM(UTC)
chrworks
Our team has just published a tutorial video on interfacing CharacterWorks with Scoreboard OCR.
You can watch it here:
dundurs
#80 Posted : Friday, September 25, 2020 5:01:13 AM(UTC)
dundurs
I wanted to share some Scoreboard OCR updates:
- Added Scripted Output option giving total user control of format validation and output sent to GFX: http://scoreboard-ocr.com/scripted_output
- Added option to load a video recording of scoreboard to be able to test at home
- Implemented new functionality to recognize geometric shapes (squares, circles, triangles, etc) that indicate timeouts, fouls and serve direction http://scoreboard-ocr.com/symbols
- Decreased CPU usage
- Implemented support for additional cameras (Logitech, etc)
We have also extended demo period, so feel free to try all the new features.
Download demo here: http://scoreboard-ocr.com/
Arturs
Similar Topics
Feature request: Scoreboard OCR support (Feature Requests)
by kricher1964 2/20/2025 9:50:37 AM(UTC)
Scoreboard OCR APP (General Discussion)
by jaialai 2/14/2024 10:16:28 PM(UTC)
Vmix and Scoreboard OCR Softball/baseball (General Discussion)
by WWLivestream 2/28/2019 2:54:12 AM(UTC)
Vmix GT with Scoreboard OCR (GT)
by azanisarri 12/21/2018 12:36:52 PM(UTC)
Free SmartScoreboard OCR (3rd Party Software and Development)
by guztavo 8/19/2018 7:58:07 PM(UTC)
5 Pages«<2345>
