Feature Requests
Delay audio more than 1 sec
Thanks: 11 times Was thanked: 7 time(s) in 4 post(s)
Not a request as such, but I have been playing around with the Gopro Hero7 locally via RTMP to NDI in vmix, and with stabalisation turned on, there seems to be about 2 secs delay, but the most you can go in vmix is -1000, so would be nice to have the ability to delay a bit more?
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 61 Location: Canada
Thanks: 1 times Was thanked: 19 time(s) in 18 post(s)
Hi Quinton,
Can you elaborate on what you want to do? vMix can delay an Audio Input up 20000 ms (or 20 seconds). Audio Input cog wheel ==> General tab ==> Delay slider
vMixGreg
Yes sorry for maybe a bit of confusion, the hero7 is weird when image stabilisation is on, when I bring it into vmix via RTMP on local network seems I would need to adjust sound to approx -2000ms to get it to match, wheras vmix only goes from -1000ms to +20000. Like the opposite of a delay.
Just tested again today, and seems thatits working great again with just +200 ms. Sorry it must have been some kind of buffer problem before in the rtmp stream, throwing it out quite a bit.
Feature Requests
