Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Hi
wich command is used to have a shortcut like Activeinput 1 or directcut 1 AND automatically plays the video? all my tests have only the result, that the active input is changed, but the video does not start automatically. all checkboxes on the input are active (autostart ect)
Thanks for helping out
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Are you using 3rd party software for this ? What specific tests have you done ?
i tried both shortcuts in vmix and panel builder
What shortcuts ? Tried any of the transition ones (CUT is one of them) ?
i tried CUT now on vmix shortcut. this works! it seems that panel builder needs an additional command. i'l keep trying.
Try this:...Go to "SETTINGS" > OPTIONS > Tick "Automatically Play Output Input with Transition"....Let us know what happens
