NDI
NDI dont work if first i open vmix
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi! As the title says.. when i turn on my spark after vmix was opened, it just dont appear. But in studio monitor i can see the ndi source fine. When restarting vmix, keeping the spark turned on, it appears así NDI source as should dos from the beginin. That un múltiple network setups with different routers. What can ve happening? Thanks!
Joined: 4/23/2017(UTC) Posts: 1,472  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Please try these things. - On all network devices try to enable IGMP snooping if they have these options - Make sure the NDI access Manager isn't used or does allow access - Use the NDI Monitor first and then vMIX. Maybe vMix can't subscribe to the stream somehow and needs another app to make the stream available first hand - Use wireshark to see what is going on in the network - Try running vMIX with admin privileges. See if that changes something.
NDI
