Can we blur out a few of the digits or the serial number as if anyone uses a vmix switch, they can see the serial number on that machine. Would be nice to at least blur it unless you know the serial number Thanks
Love VMIX! Gene
 1 user thanked genegreenwood for this useful post.
+1 Never thought of that, but that would be a smart move. We have a lot of interns. Serial should maybe be hidden like a password.
 1 user thanked Prodution Dept. for this useful post.
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Joined: 5/20/2017(UTC) Posts: 62   Location: Philippines Thanks: 169 times Was thanked: 3 time(s) in 2 post(s)
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
++1 password protected projects
Joined: 4/2/2013(UTC) Posts: 53  Location: Hungary Thanks: 3 times
Joined: 8/2/2013(UTC) Posts: 1,098   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
Joined: 6/6/2017(UTC) Posts: 40 Location: Mississippi, United States
Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
+1 - But I think it should be an option.
Perhaps a button next to where the key appears, clicking it will enable you to set a PIN and conceal your registration key. To reveal the key again, click the button, and re-enter the PIN. This way someone who rents vMix systems could conceal / unconceal at will when they need to reference or change their key, but the average user wouldn't be affected and could still reference their key easily from within the program.
Rank:: Advanced Member
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
Why do you want to blur the key? Is not the possibility to enforce logging in with an e-mail address and password at vmix.com/activate sufficient?
 1 user thanked richardgatarski for this useful post.
