recording file is damaged in mp4
The problem is introduced using FFMPEG to record PGM out and I noticed that, trying to playback the resulting file with vlc. Endless wait and no playback.  I fix the file using this command: ffmpeg -i tg_no_good.mp4 -c:v copy -c:a copy tg_good.mp4 From a brief analysis, seems vmix marks the video file like it was VBR but instead it is CBR. v1p3r@viperbox:~/Video/temp$ mediainfo --fullscan 'tg_good.mp4' | grep 'mode' Frame rate mode : CFR Frame rate mode : Constant Bit rate mode : CBR Bit rate mode : Constant Compression mode : Lossy Compression mode : Lossy v1p3r@viperbox:~/Video/temp$ mediainfo --fullscan 'tg_no_good.mp4' | grep 'mode' Overall bit rate mode : VBR Overall bit rate mode : Variable Frame rate mode : CFR Frame rate mode : Constant Bit rate mode : VBR Bit rate mode : Variable Compression mode : Lossy Compression mode : Lossy I can provide both files to analyze if needed. PS: if i use the "internal" mp4 encoder, outputted video files are perfect playing, but quality seems a bit lower then the one produced by the "fixed" ffmpeg.
