ben1000
#1 Posted: : Wednesday, May 1, 2019 12:37:31 AM(UTC)
ben1000
Hi, Martin and co! :)
It was great to meet you at NAB...
I'm not sure if you'll recall (as you were super-busy), but after our interview, I showed you that little bug with using a MS joystick to do a virtual PTZ pan of a Virtual Input created from a 4K source (not creating a virtual preset, but rather a virtual input).
When you pan with the on-screen buttons, it works fine, but when you pan with the joystick, it changes the ORIGINAL video source, and not the virtual input...
At the time, you seemed to think this was a fairly small bug that could be addressed... It would make a big difference in our workflow if that was doable! :)
Love you guys! Hope all your travels are safe...
Best,
Ben
Benjamin Freedman
PrimeImage Media
ben@PrimeImageMedia.com
www.PrimeImageMedia.com
kevev
#2 Posted : Wednesday, May 1, 2019 1:44:29 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
+1
