M4R3C
#1 Posted : Sunday, April 28, 2019 11:08:49 AM(UTC)
M4R3C
Czech Republic
It is possible to design a background length in GT Title. (one color) to adapt to text?
With the ability to change live.
Thank you very much for all the information.
I found identical Topics. (two months old)
Is there any development?
Or a combination of how to achieve a result?
Regards
Petr Mareček
My idea.
I'm sending an image
Sorry my bad English..:(
richardgatarski
#2 Posted : Wednesday, May 8, 2019 1:26:49 AM(UTC)
richardgatarski
Hi Petr,
As far as I know it is not possible - too bad.
The help file http://help.vmix.com/graphics/1/TextBlock.html says
Any formatting applied to the TextBlock such as borders and fill, apply to the text only and not to the overall bounding box.
To add box style effects, add a Rectangle object and position this underneath the TextBlock.
But that Rectangle is not tied to the length of the TextBlock.
Where did you find that "identical Topics"? I want to look into this and make a Feature Request, as I think it is an important need shared by many.
Thanks.
Barney Box Lane
#3 Posted : Wednesday, May 8, 2019 6:11:56 PM(UTC)
Barney Box Lane
you could use a font that has a background there's a few out there that would look like what you've typed
richardgatarski
#4 Posted : Wednesday, May 8, 2019 7:25:49 PM(UTC)
richardgatarski
Our customers typically have their own, or a specified font, so that workaround is a nono.
richardgatarski
#5 Posted : Friday, May 24, 2019 9:18:36 PM(UTC)
richardgatarski
Pls see (and make a +1 there if you agree) the Feature Request GT - background following text length
Guest (7)
