bradweber1982@gmail.com
#1 Posted : Wednesday, April 24, 2019 8:30:42 PM(UTC)
Been working all morning to find a solution but can't come across one. Here is my issue: I use a focusrite 2i2 with a Rode Procaster Microphone. My microphone is outputting to my laptop speakers which I know is a simple fix, but my question is this: if I turn off the master output to my speakers, how can I integrate Skype calls? I do live interviews quite frequently and want my audience to still hear the caller. What is the fix for this?
Also, how do I add an image to my webcam feed? I have a logo that I use and I only use it when my webcam is selected but I can't find an option to turn it on automatically when I am using the webcam. Thanks!
mavik
#2 Posted : Saturday, April 27, 2019 4:57:28 AM(UTC)
mavik
Originally Posted by: bradweber1982@gmail.com Go to Quoted Post
If I turn off the master output to my speakers, how can I integrate Skype calls?
Make sure you select your speakers as the monitor/headphone destination and select an unaudible destination as your master. -> Settings->Audio Outputs
With Multiview
