2 Pages<12
Rinsky
#21 Posted : Monday, March 18, 2019 8:29:03 PM(UTC)
Rinsky
Just saw the new update:
* Fixed issue with Restart not working correctly with GT Tickers
I thought that this would fix the tickers when using type "Add", because I couldn't play the same ticker with the same data twice, without reloading the input.
I don't want the text to scroll through continuously, so "replace" is not an option. I just want it to always start at the beginning when using that input and only play the text once. Is that possible?
ask
#22 Posted : Tuesday, March 26, 2019 3:51:17 PM(UTC)
ask
TRIGGERS: When configuring an OnCompletion trigger for a fade back to a PowerPoint input I get a dropdown option which allows me to select the slide number to transition back to. However it does not update the trigger to that selected slide. Rather it sets the transition back to the Current slide. Is this as designed?
Cheers
Andrew
Ariel
#23 Posted : Thursday, April 25, 2019 12:22:58 AM(UTC)
Ariel
Congo, The DRC
is it possible to move vmix from one machine to another for technical reasons (panes, defective state, ....) and keep the license?
Mari
#24 Posted : Thursday, April 25, 2019 2:29:19 AM(UTC)
Mari
Netherlands
Can licenses be installed on more than one PC?
Each license can be installed on up to two PCs or Laptops in total as long as vMix is not being used on both at the same time.
To install your license on to the second machine, enter the key as normal and follow the instructions in the error message when prompted.
Licenses can also be transferred to a new computer if required as long as vMix is no longer being used on the previous machine.
N.B: A reasonable number of transfers are permitted to cater for computer upgrades, hardware failures and other situations where the previous machine becomes inoperable.
This means a license should not be considered a operator, site or floating license.
Last Updated: Friday, 15 February 2019 3:11:52 AM
Vytautas
#25 Posted : Thursday, June 13, 2019 2:52:22 AM(UTC)
Vytautas
Lithuania
Hello I am just wondering when vMix 23 gonna come out?
#26 Posted : Thursday, June 13, 2019 3:06:50 AM(UTC)
Yesterday
But don't bother as 24 will be out tomorrow
Peachesontour
#27 Posted : Thursday, July 11, 2019 8:34:22 AM(UTC)
Peachesontour
Brazil
Hi there,
The new vMix 22 is great! However I encountered a localisation bug, in the SetText shortcut. I have a scoreboard that shows scores from 60 to 80, with whole numbers and also half scores permitted.
I set 2 shortcuts using +=1 and -=1 to increment and decrement the scores. I also created a shortcut for +=0.5 for the half scores. I am in Brazil and the scores show with the correct localisation here using a comma in place of the decimal point. e.g. 72,5. However when I hit the increment or decrement shortcuts after using a half score, it ignores the decimal separator and makes all the digits part of the whole number. Ie. 72,5 becomes 725, and increments to 726, not 73,5. Can you fix this?
#28 Posted : Thursday, July 11, 2019 12:28:13 PM(UTC)
All data given to the API must use decimal points instead of commas, it is not region specific.
2 Pages<12
