Multiple Instance bug in vMix22
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
I have configured a button on Stream Deck to start vMix and I have disabled "Enable Multiple Instances" in Settings.
But still I can launch muliple instances of vMix by pressing the button on Stream Deck..
Now it seems to launch only once as it should.. Toggled the setting for a few time.
Chap
Really strange: Now it allows launching of multiple instances of vMix again thru Stream Deck..
Chap
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
vMix can only prevent multiple instances when it has been running long enough to be "initialized". If you press a button that starts a program quickly enough, then it will run twice and there is not much that can be done about it unfortunately.
Martin vMix
