	Feature Requests
	Instant Replay Interface via NDI
 Joined: 6/20/2015(UTC) Posts: 15 Location: Baton Rouge
  Thanks: 22 times Was thanked: 3 time(s) in 3 post(s)
                Hey, folks
  This idea popped into my head while I was at the NAB Show while I was chatting to someone about vMix's Instant Replay functionality.
  In certain situations it would be beneficial to have a dedicated Replay operator to handle that aspect of the broadcast. Trouble is, to do that effectively, you need to have a multiple monitor setup so the replay operator has his own screen to view the Instant Replay interface - which is all well and good but what if you wanted to create a little distance between the TD and said operator?
  Here's a possible solution - make the Instant Replay interface an additional NDI output from that same selection area in the Output Settings. That way an operator can use Newtek's NDI Monitor to see the list of replay cuts, create a highlight playlist, cue up the next playback and so much more - all at a respectable distance away from the TD using a Shuttle or X-Keys controller along with a keyboard.
  Hope this gains traction - keep up the good work Martin, Tim et al.
  Antony Lightfoot
              1 user thanked tonylightfoot for this useful post.
	Feature Requests
