Yvlaguit
#1 Posted : Thursday, April 11, 2019 12:28:37 PM(UTC)
Yvlaguit
Canada
Hello Vmix Community!
My vMix 4k 22.0.0.54 setup is 3 cameras into Avermedia Live gamer 2 and 2 Logitech usb cameras. In my inputs every cameras display correctly but in multicorder the usb cameras are mirrored and flipped upside down. The same cameras when I record the ouptut are showing ok.I tried rebooting,enable-disable mirror in the input section and search for an option in multicorder but found Nothing. Anybody else encountered this behaviour or have an idea of what I could have missed? On Windows 10 , latest updates, i9-9900k, 64 Gb Ram, msi 1070ti.Thanks for your help!
Yvlaguit
#2 Posted : Tuesday, April 16, 2019 2:25:22 AM(UTC)
Yvlaguit
Canada
After some tests it does so only with the vMix avi format. Every other formats display ok.
Cormac
#3 Posted : Tuesday, April 16, 2019 7:51:19 AM(UTC)
Cormac
I've had this as well but only on 1 multicorder input out of 6.
Yvlaguit
#4 Posted : Tuesday, April 16, 2019 8:40:02 AM(UTC)
Yvlaguit
Canada
Was it a USB camera too?
PaulS
#5 Posted : Monday, July 13, 2020 5:01:17 AM(UTC)
PaulS
FWIW I'm seeing this too. It's specifically with USB cameras using the vMix codec. vMix Call inputs recorded at the same time all look normal, only the USB cameras are inverted.
