66 Pages«<3435363738>»
yosik
#701 Posted : Monday, April 8, 2019 12:47:40 AM(UTC)
yosik
OK.....I am still confused.
If I understood you correctly, I should have done something like that:
<vMixFunctionReference>
<Description>OpenPreset</Description>
<Function>OpenPreset</Function>
<FormatString>Function=OpenPreset&amp;Value={2}</FormatString>
<StringDescription>C:\Users\ms\Documents\Vmix Presets\402.vmix</StringDescription>
</vMixFunctionReference>
Replacing Path with the actual path of my preset.
I do get the folder window to open, but the selected preset is NOT selected and Vmix is waiting for me to, manually, choose the preset (which, of course, defeats the purpose).
elgarf
#702 Posted : Monday, April 8, 2019 12:56:56 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@yosik, no. You need set path in UTC in parameter of function.
StringDescription is just description of string parameter, which you see when add function to script in button.
I provide you right XML string, just paste it in Functions.xml file.
Then delete this function in button script (if you try to edit script), because functions in scripts does not update when you change Functions.xml file.
Each function in .xml file just description, it contain only static data.
yosik
#703 Posted : Monday, April 8, 2019 1:22:44 AM(UTC)
yosik
Yesssssss!!
Thank you.
You're the MAN.
Works like a charm
Respect....
elgarf
#704 Posted : Tuesday, April 9, 2019 12:04:16 AM(UTC)
elgarf
Russian Federation
@yosik, good luck!
But check event viewer too, please. So I can fix crash.
piterkim
#705 Posted : Saturday, April 13, 2019 1:48:43 AM(UTC)
piterkim
Korea, Republic Of
why not oline...???
offline 0.0???
elgarf
#706 Posted : Saturday, April 13, 2019 2:07:10 AM(UTC)
elgarf
Russian Federation
@piterkim, is vMix started?
elgarf
#707 Posted: : Tuesday, April 16, 2019 4:40:35 PM(UTC)
elgarf
Russian Federation
Updated with accessing list items, also now you can access inputs by number in expressions.
Universal Title Controller
Nicosan
#708 Posted : Friday, May 17, 2019 3:48:45 AM(UTC)
Nicosan
Ukraine
Only vMix and UTC
Championship of Ukraine on hockey among women
thanks 1 user thanked Nicosan for this useful post.
elgarf on 5/17/2019(UTC)
JAIRODJ
#709 Posted : Friday, May 31, 2019 8:07:40 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi, I have a query.
Please, if you can help me.
How could you activate a button (overlay) depending on the state of one of the vmix inputs.
I see that vmix in localhost, throw the status in [Running and Paused]
state: Running >>> (Input 1)
overlayIN 1
timer: 15000
overlayOUT 1
state: Paused
no action
elgarf
#710 Posted : Friday, May 31, 2019 5:12:22 PM(UTC)
elgarf
Russian Federation
@JAIRODJ, it's a bit complex script =)
At first I set variable, which indicate previous state of Input.
If state was changed, I update variable and check if it's value is 'Running'.
If variable value is equal to 'Running' play overlay.
Wait a bit, then go to the start of the script.
Maybe it will be better to split script into two buttons...
JAIRODJ
#711 Posted : Saturday, June 1, 2019 9:27:31 AM(UTC)
JAIRODJ
Thanks, I will try and tell you how it was
JAIRODJ
#712 Posted : Wednesday, June 5, 2019 6:32:08 AM(UTC)
JAIRODJ
Hi, I tried to use the running data, but it did not work.
when adding the condition _var0 == Running, there is no result.
however, when using position, duration, number has worked.
I have tried the query to the entry in all: type, number, etc. and if it returns each value in text, but when comparing or matching it does not have any effect on the condition.
I am not very understood in this coding, I do not know if something will have to see that it is text or numbers what is obtained in the variable _var0
elgarf
#713 Posted : Wednesday, June 5, 2019 2:47:21 PM(UTC)
elgarf
Russian Federation
@JAIRODJ,
Hi.
'Running' must be in single quotes because it's string value.
So it will look like
Code:
_var0 == 'Running'
Siroki
#714 Posted : Friday, June 7, 2019 9:09:46 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Sometimes it just need to hit Update state and it comes online ;)
bgbenni
#715 Posted : Tuesday, June 11, 2019 2:22:32 AM(UTC)
bgbenni
Germany
is this working on UTC ?
I get from a csv file information for my scoreboards, is it possibly if the data is charging in the csv (scoreboard) that vmix is make a cut or show a new transmission Automatik.
As Exempel csv Information round 1 is change to round 2 now I would like that vmix is Change from cam 1 to cam 2 automatic.
I hope you understanding and maybe someone have a Idee
Thx
elgarf
#716 Posted : Wednesday, June 12, 2019 6:24:22 PM(UTC)
elgarf
Russian Federation
@JAIRODJ, @bgbenni, check new version of UTC. I've added ValueChanged function, which will help you.
script 01.png (39kb) downloaded 17 time(s).
Above is the script for JAIRODJ.
@bgbenni, you can make condition for every state of round, something like that:
Code:
ValueChanged _('Inputs[{0}].Elements[round].Text')
  Condition _('Inputs[{0}].Elements[round].Text') == 1
    <SomeActions>
  ConditionEnd
  Condition _('Inputs[{0}].Elements[round].Text') == 2
    <SomeOtherActions>
  ConditionEnd
ConditionEnd
Timer 1000
GoTo 0
I've also added descriptions for functions.
Conditions and expressions in UTC are very powerful, you can make some beautiful things, even in basic version of vMix. Though scripts are not really realtime (you should make delays, because http API queries are asynchronous).
Maybe I should make text versions of scripts for easy sharing.
bgbenni
#717 Posted : Wednesday, June 12, 2019 7:27:31 PM(UTC)
bgbenni
Germany
Wow ok I will test it the next weeks ! Thx
JAIRODJ
#718 Posted : Thursday, June 13, 2019 7:54:39 AM(UTC)
JAIRODJ
Hey, thanks @elgarf for the support.
I managed to solve it.
Also I managed to create a way to automate content in vmix using UTC functions
with your help I managed to add music autotitle, now you see) and it works decently (it helps the moment).
Some events arose:
When the (GoTo = 0) is used to repeat the instructions and the button is activated,
an infinite loop is practically created .. and can not be interrupted.
If for some reason you want to stop, you can not and if you want to delete or close the button,
UTC collapses (does not respond), so you must force the closure.
Well also want to consult you if it is possible that, when a project is opened,
it activates automatically some UTC function (activate a button, etc.)
elgarf
#719 Posted : Thursday, June 13, 2019 3:51:34 PM(UTC)
elgarf
Russian Federation
@JAIRODJ, there is [Stop] button in button widget caption, but looks like I stop background worker not correctly when removing widget, I'll fix it in the next update.
At now you can stop script manually.
elgarf
#720 Posted : Monday, June 17, 2019 3:49:04 PM(UTC)
elgarf
Russian Federation
Updated UTC, so you can remove buttons with infinite loops, import & export scripts.
Download Universal Title Controller
Guest (10)
