GT
video hive broadcast template + vmix
Joined: 4/8/2019(UTC) Posts: 2 ![Greece Greece](/Content/images/flags/GR.png) Thanks: 1 times
Hi Guys i would appreciate your input on how i can import an after effects project bought from videohive into gt and use them on our live streams.
the bought template includes the below 1. 4 Information holder… 2. 2 Next/Later holder… 3. 2 Sponser holder… 4. 1 Tonight holder… 5. 1 weekly information holder…. 6. 2 Next/Later Lower-third holder… 7. 2 Sponser Lower-third holder… 8. 2 Social Network holder… 9. Channel holder… 10. Logo holder…
looking for a way to import them and edit them via vmix gt editor
any ideas/suggestions?
best Vas
Was thanked: 8 time(s) in 2 post(s)
Hey Vas,
Most likely you will need to render the elements from the template you bought as PNG Seqs (RGB + Alpha) in AE, then add them to GT (select the first frame and GT will recognize its a SEQ), then select animation and sequence for your transition in and out for the layer, adjusting the duration accordingly.
Do remember that you should not have any information in the holders on your PNG Seq renders as GT cant adjust them after.
Best of luck!
![thanks](/Themes/yafpro/heart_small.png) 2 users thanked OPL for this useful post.
GT
