GT
hide/show different layers of GT Title with datasource change
Joined: 3/21/2019(UTC) Posts: 1  Location: Islamabad Was thanked: 1 time(s) in 1 post(s)
I am new to vMix and trying to achieve bellow functionality. I want to show soccer match feed on live stream of match. For achieveing this I have created a new input with multiple layers like (1 for scoreboard, 1 for team information, 1 for match details etc.). I had binded all the components of every layer with data source attributes so for showing any particular layer I am sending its valid data whereas for hiding layers I am sending transparent images and empty data.
Now issue is I am not sure whether it's the correct way or not. Can anyone tell me how I can handle switching between multiple inputs or hide/show of layers within single input using web API or datasource change.
I have to add animations and replay functionality as well.
Advance Thanks for giving time and response.
Regards, Sant
 1 user thanked sanat for this useful post.
I am in the same situation. I also needs a possibility to hide/show layers by using datasource values. I want to create a ranking list with a layer per line. Empty ranking lines should be invisible. Perhaps there is already a work around.
Thanks Alex
There is no conditional options in GT titles, only a animation(hide/unhide) on Datachange in and/or out If its really important with XAML titles it can be done with code
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Thanks Alex If your datasource is an Excel spreadsheet, one workaround could be to create several background images (like 5lines.png, 6lines.png and so on) and include a condition in your *datasource*. It is possible to use a path to an image file in data sources: https://www.vmix.com/hel...m?DataSourcesImages.html
Thanks Alex If your datasource is an Excel spreadsheet, one workaround could be to create several background images (like 5lines.png, 6lines.png and so on) and include a condition in your *datasource*. It is possible to use a path to an image file in data sources: https://www.vmix.com/hel...m?DataSourcesImages.html Thanks for the work around, but for me it is not really a good solution. If you want to change the design you need to change all the images too. And also you can not use individual animation settings for each line. In this case it will be much easier to use XAML. Alex
Originally Posted by: doggy  There is no conditional options in GT titles, only a animation(hide/unhide) on Datachange in and/or out If its really important with XAML titles it can be done with code I already works with Blend/XAML. But its really hard to work with this. I just hope GT Designer will be more and more improved so it can replace Blend/XAML. Alex
Joined: 10/10/2017(UTC) Posts: 5 Location: Sydney, AUS
+1 for this.
I have an event where I display a fundraising feed and some donations have a message while others don't it would be great not to have a blank area when no one leaves a message.
Originally Posted by: jum01  +1 for this.
I have an event where I display a fundraising feed and some donations have a message while others don't it would be great not to have a blank area when no one leaves a message. Does your license allow for scripting ? then do the same as when putting codebehind in xaml titles . Test on the contains a message in the textbox and hide/display whatever you want accordingly
GT
