groovestar
#1 Posted : 6 years ago
groovestar
Canada
Currently you can't preview an event(s)...that would be a nice feature to ensure clips are correct.
Also nice...would be the ability to see how long your event clips add up to (total time of clips only show once you start playing them)...currently I have to manually count the seconds...not ideal in a live broadcast with a producer wanting to know how long your highlite reel is.
Being able to prioritize which camera angle (camera 4, then 2, then 1) instead of going numeric from 1 would also be helpful.
Henrik
#2 Posted : 6 years ago
Henrik
Germany
+1
kevev
#3 Posted : 6 years ago
kevev
Was thanked: 9 time(s) in 5 post(s)
+1
Radiotvpat1982
#4 Posted : 6 years ago
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
+1 to all of those.
I typically will drag my in point to preview my file if I am not certain the length is what I want. It is a workaround but I am used to that a this point.
I never thought about the fact of not being able to see the time before it plays. A running tally would be nice. Its easy if you have all clips the same length but if not I can see how that would be needed. I know some have mentioned that VMIX Replay is not intended to be a full scale solution but I think it can and should be.
I asked a while back about what to do if you want your clips played out in a certain order. Just makes sense to be able to do that.
Allan Rokkedahl
#5 Posted : 6 years ago
Allan Rokkedahl
Denmark
+1
toastbh
#6 Posted : 6 years ago
toastbh
+1
QstreamTV
#7 Posted : 6 years ago
QstreamTV
Denmark
+1
Barney Box Lane
#8 Posted : 6 years ago
Barney Box Lane
you can make a play event in preview shortcut button
marknotts
#9 Posted : 5 years ago
marknotts
+1 to all of these
