66 Pages«<3334353637>»
chococrispis35
#681 Posted : Sunday, March 31, 2019 1:35:04 AM(UTC)
chococrispis35
elgarf
in the UTC directory I had the files Processing.NDI.Lib.x86.dll and Processing.NDI.Lib.x64.dll but the program indicated me error and crashed, the computer was getting very very slow, I installed the program of newtek ndi and it worked perfectly
elgarf
#682 Posted : Sunday, March 31, 2019 7:57:43 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@chococrispis35, looks like, you need install Visual C++ Redistributable for Visual Studio 2015.
mudpatch
#683 Posted : Monday, April 1, 2019 1:08:59 PM(UTC)
mudpatch
Can you look at the Select Playlist command in the latest version - for some reason its doesn't seem to be working and when i go back to the January version of UTC its working for me.
Originally Posted by: elgarf Go to Quoted Post
I think, I've fixed clock widget.
Also I made some design changes into properties window. Now it should look a bit friendlier.
Universal Title Controller
elgarf
#684 Posted : Monday, April 1, 2019 4:57:22 PM(UTC)
elgarf
Russian Federation
@mudpatch, oops, looks like I broke string parameters, that doesn't enquoted.
Fixed it and region widgets.
thanks 1 user thanked elgarf for this useful post.
mudpatch on 4/4/2019(UTC)
Brutuss
#685 Posted : Monday, April 1, 2019 11:38:34 PM(UTC)
Brutuss
How to import excel rows an columns?
like a UTC and Excel on Baseball Game
gokily
#686 Posted : Tuesday, April 2, 2019 7:30:40 PM(UTC)
gokily
Croatia
Is it possible to have timer exec_link start/stop to be state dependent (overlayInputToggle)?
elgarf
#687 Posted : Tuesday, April 2, 2019 8:44:50 PM(UTC)
elgarf
Russian Federation
@gokily, you can use OverlayInputToggle into button script.
gokily
#688 Posted : Tuesday, April 2, 2019 8:47:26 PM(UTC)
gokily
Croatia
Yeah, but how can I link it so when its on out state to trigger exec link stop ? Right now it only resets the timer (triggers only start timer), does not stop it
elgarf
#689 Posted : Tuesday, April 2, 2019 10:45:32 PM(UTC)
elgarf
Russian Federation
That's a bit harder, but I try to make sample.
So, you need to start timer, when overlay is on & stop it, when overlay is off, right?
Is overlay controlled through UTC, or it can be fired anywhere else?
Because if it controlled through UTC, there is no difference in this two methods.
gokily
#690 Posted : Tuesday, April 2, 2019 10:50:32 PM(UTC)
gokily
Croatia
I have timer mapped to overlay and start and stop exec:
new timer button with state dependent checked, 1. overlaytoggle, 2. exec start, 3 exec stop
I assume exec stop cannot work here (in the same button)?
Everything is triggered with UTC
elgarf
#691 Posted : Tuesday, April 2, 2019 11:14:48 PM(UTC)
elgarf
Russian Federation
You want start/stop with one button?
gokily
#692 Posted : Wednesday, April 3, 2019 12:09:45 AM(UTC)
gokily
Croatia
Yeah,not sure if its possible thats why I'm asking
One more thing, is it possible to control AUDIO ON/OFF via UTC?
Siroki
#693 Posted : Friday, April 5, 2019 8:22:30 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Druze za koji sport ti treba?
Siroki
#694 Posted : Saturday, April 6, 2019 12:14:03 AM(UTC)
Siroki
Originally Posted by: chococrispis35 Go to Quoted Post
UTC Vmix Basketball
Great job!
elgarf
#695 Posted : Saturday, April 6, 2019 7:58:12 PM(UTC)
elgarf
Russian Federation
@gokily, I've made an update, so you can make what you want.
Let's we have two ExecLinks: OverlayIn and OverlayOut. They can refer to buttons AND to timer events. So one ExecLink can call two actions.
Then we make button with ExecLink function, where string parameter will be choosed dynamically, based on Overlay.ActiveInput value from vMix API.
Code:
if(_('Overlays[0].ActiveInput') == '', 'OverlayIn', 'OverlayOut')
OR you can use Condition/ConditionEnd function, and make one button for everything:
Code:
Condition => [_('Overlays[0].ActiveInput')] [==] ['']
     OverlayInputIn => [YourInput], [1]
     ExecLink [OverlayIn]
     GoTo 8 //Avoid 'else' case
ConditionEnd
OverlayInputOut => [1]
ExecLink [OverlayOut]
None
UTC can call any function from vMix shortcut reference. You can add it to the functions.xml by yourself, by copying existing function and editing it.
yosik
#696 Posted : Sunday, April 7, 2019 9:24:10 PM(UTC)
yosik
Issue launching ver 06.04.2019.
It works on one machine (remote, not the one with vMix installed on it), but I tried to launch it on the vMix machine and it doesn't open.
The previous version, 22.03.2019 does open on the vMix machine.
Any idea?
TY
elgarf
#697 Posted : Sunday, April 7, 2019 10:02:28 PM(UTC)
elgarf
Russian Federation
@yosik, can you look into windows event viewer, there will be two events, related to the UTC error.
I think if you delete dll's from DataSources folder, it will start.
yosik
#698 Posted : Sunday, April 7, 2019 11:23:12 PM(UTC)
yosik
Sorry, but I need more guidance... I can't find any UTC mention in the Event Viewer. And where is the DATASOURCES folder? Do you mean the DataProviders?
TY
yosik
#699 Posted : Sunday, April 7, 2019 11:26:37 PM(UTC)
yosik
Another topic.
I want to open a vmix preset with UTC.
I added the OpenPresets function in the Functions.xml file and it works (opens the preset folder), but I don't see how to add the parameters (value?)into UTC.
TY
elgarf
#700 Posted : Monday, April 8, 2019 12:08:02 AM(UTC)
elgarf
Russian Federation
@yosik, yep. DataProviders.
There will be "Application Error" and ".NET Runtime" errors in Application section of windows event viewer.
You can take "KeyPress" function as base. Should be like that.
Code:
<vMixFunctionReference>
    <Description>OpenPreset</Description>
    <Function>OpenPreset</Function>
    <FormatString>Function=OpenPreset&amp;Value={2}</FormatString>
    <StringDescription>Path</StringDescription>
  </vMixFunctionReference>
Guest (16)
