66 Pages«<3233343536>»
elgarf
#661 Posted : Tuesday, March 26, 2019 3:59:55 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@fuimpa, it should work ok by default without toggling LIVE. Just try.
chococrispis35
#662 Posted : Tuesday, March 26, 2019 6:15:19 AM(UTC)
chococrispis35
UTC Vmix Basketball
thanks 2 users thanked chococrispis35 for this useful post.
elgarf on 3/26/2019(UTC), Siroki on 4/6/2019(UTC)
stevespaw
#663 Posted : Tuesday, March 26, 2019 6:31:56 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Maybe this has been covered, but I am just now getting around to trying your nice app.
On the Timer widget, Is it possible to repeat events?
Maybe it is doing it already, for example I want to record at the same times everyday. It says "no new event scheduled" does that mean just for today?
Thanks,
Steve
stevespaw
#664 Posted : Wednesday, March 27, 2019 1:30:09 AM(UTC)
stevespaw
I have a question, I want to "auto load" a .vmc file.
If I try to open an .vmc file - using open with - and then select vmixcontroller.exe, the UTC app tries to start but it never connects in any way and then goes away. If I start vmixcontroller.exe by itself everything is fine. I need to be able to launch a saved VMC project for my workflow.
Is this just me or is it an issue with my setup?
Thanks,
Steve
elgarf
#665 Posted : Wednesday, March 27, 2019 2:29:17 AM(UTC)
elgarf
Russian Federation
@stevespaw, I'm thought about autoloading controller.
Wait until next update, please.
thanks 1 user thanked elgarf for this useful post.
stevespaw on 3/27/2019(UTC)
elgarf
#666 Posted : Wednesday, March 27, 2019 5:27:58 PM(UTC)
elgarf
Russian Federation
@stevespaw, I've added loading controllers through command line, check the latest update.
Universal Title Controller
stevespaw
#667 Posted : Thursday, March 28, 2019 12:42:00 AM(UTC)
stevespaw
Thanks a lot, this works perfectly!
C:/Users/ss/Documents/UTC/vMixController.exe "C:\Users\ss\Documents\UTC Test.vmc"
Also the Windows .vmc file "Open With"
I look forward to using this in very user friendly project.
I still have this basic timer question, I am too lazy to wait until the next day to test. :-)
Thanks again,
I hope to update you on how I use this.
Best,
Steve
Thanks,
Steve
elgarf
#668 Posted : Thursday, March 28, 2019 1:03:47 AM(UTC)
elgarf
Russian Federation
@stevespaw,
Yes, "no new events scheduled" is just for today. Now I think, that's a bit confusing, so I'll make Clock widget look into future deeper =)
mudpatch on 3/29/2019(UTC)
elgarf
#669 Posted : Friday, March 29, 2019 4:18:49 AM(UTC)
elgarf
Russian Federation
I think, I've fixed clock widget.
Also I made some design changes into properties window. Now it should look a bit friendlier.
thanks 3 users thanked elgarf for this useful post.
stevespaw on 3/29/2019(UTC), Chircanu on 3/29/2019(UTC), mudpatch on 4/1/2019(UTC)
stevespaw
#670 Posted : Friday, March 29, 2019 5:23:10 AM(UTC)
stevespaw
This seems to work great so far!
Thanks a lot for these updates,
Best,
Steve
stevespaw
#671 Posted : Friday, March 29, 2019 6:30:09 AM(UTC)
stevespaw
Spoke too soon.
I just adjusted the times and it worked fine, but if I made and changes to the referenced button, or made a new one the timer does not fire the button.
Steve
desmar
#672 Posted : Friday, March 29, 2019 10:41:05 AM(UTC)
desmar
Canada
@Elgarf
Found a bug with regions widgets.
When I try to add another widget after the region widget is created and overlay it onto region widget, new widget goes behind the region widget and not in front of it.
But if I duplicate region it, it goes behind all other widgets and remove the original region widget all displays ok.
elgarf
#673 Posted : Friday, March 29, 2019 1:00:09 PM(UTC)
elgarf
Russian Federation
@stevespaw, @desmar,
I'll look at this.
elgarf
#674 Posted : Friday, March 29, 2019 5:33:54 PM(UTC)
elgarf
Russian Federation
@stevespaw, can you share .vmc file?
Also:
Clock fire event not by name, but by ExecLink, it can be a bit confusing. Also clock doesn't tick if properties window is opened.
chococrispis35
#675 Posted : Saturday, March 30, 2019 3:45:26 AM(UTC)
chococrispis35
ELGARF the utc no working in a pc i7-3770, 32 ram, ssd 256gb
is this the log:
2019-03-29 10:11:16.9322 INFO Loading mapped functions.
2019-03-29 10:11:17.0102 INFO Loading templates.
2019-03-29 10:11:17.1350 INFO Searching for data providers.
2019-03-29 10:11:17.4470 INFO Loading window settings.
2019-03-29 10:11:17.4470 ERROR Current domain unhandled exception. System.DllNotFoundException: Unable to load DLL 'Processing.NDI.Lib.x86.dll': No se puede encontrar el módulo especificado. (Exception from HRESULT: 0x8007007E)
at NewTek.NDIlib.UnsafeNativeMethods.destroy_32()
at NewTek.NDIlib.destroy() in C:\Users\elgar\Source\Repos\vMixUTC\NDILibDotNet2\Pinvoke\Processing.NDI.Lib.Interop.cs:line 33
at NewTek.NDI.Finder.Dispose(Boolean disposing) in C:\Users\elgar\Source\Repos\vMixUTC\NDILibDotNet2\Finder.cs:line 139
at NewTek.NDI.Finder.Finalize() in C:\Users\elgar\Source\Repos\vMixUTC\NDILibDotNet2\Finder.cs:line 112
2019-03-29 10:11:58.9390 INFO Loading mapped functions.
2019-03-29 10:11:58.9858 INFO Loading templates.
2019-03-29 10:11:59.1106 INFO Searching for data providers.
2019-03-29 10:11:59.2666 INFO Loading window settings.
2019-03-29 10:14:39.3381 INFO Loading mapped functions.
2019-03-29 10:14:39.3849 INFO Loading templates.
2019-03-29 10:14:39.5097 INFO Searching for data providers.
2019-03-29 10:14:39.6657 INFO Loading window settings.
2019-03-29 10:24:15.4933 INFO Loading mapped functions.
2019-03-29 10:24:15.5869 INFO Loading templates.
2019-03-29 10:24:15.7117 INFO Searching for data providers.
2019-03-29 10:24:16.0081 INFO Loading window settings.
2019-03-29 10:24:42.2925 INFO Loading mapped functions.
2019-03-29 10:24:42.3393 INFO Loading templates.
2019-03-29 10:24:42.4485 INFO Searching for data providers.
2019-03-29 10:24:42.6045 INFO Loading window settings.
2019-03-29 10:25:00.8254 INFO Loading mapped functions.
2019-03-29 10:25:00.8722 INFO Loading templates.
2019-03-29 10:25:00.9970 INFO Searching for data providers.
2019-03-29 10:25:01.1374 INFO Loading window settings.
muy pc running slow when i star utc program and error ocurr, the program crashes
thanks
stevespaw
#676 Posted : Saturday, March 30, 2019 5:32:45 AM(UTC)
stevespaw
Also:
This was totally it. I did not remember that I had figured that out before.
All is well now.
Thanks,
Steve
elgarf
#677 Posted : Saturday, March 30, 2019 11:41:27 AM(UTC)
elgarf
Russian Federation
@chococrispis35, check Processing.NDI.Lib.x86.dll in UTC folder. Is it exist?
chococrispis35
#678 Posted : Saturday, March 30, 2019 3:17:56 PM(UTC)
chococrispis35
i installed ndi newtek software, still working!
elgarf
#679 Posted : Saturday, March 30, 2019 3:36:50 PM(UTC)
elgarf
Russian Federation
That means all ok?
Slavko
#680 Posted : Saturday, March 30, 2019 8:45:10 PM(UTC)
Slavko
Poland
Updated UTC with:
1) password protection of controllers (click SHIFT+Lock button to protect your controller)
2) fixed scrolling by mouse wheel
@Slavko, check the latest update.
Great ! :)
Guest (14), victoraraujorua
