Joined: 2/2/2019(UTC) Posts: 13  Was thanked: 2 time(s) in 1 post(s)
I thought the lower part was only for formating time did not know it can be used for aliases.Thank you very much!
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
@gokily, looks like I need title it =) Btw, there are a lot of possibilities in UTC, which are hidden because I too lazy to write manual. Also today I made several changes in UTC: - In _() function you can refer to element by it's name _('Inputs[{0}].Elements[Description].Text')
- Pictures into buttons
- Captionless widgets (so you can made more compact switcher)
I'll push update later.
New update is ready. There is major change: Pictures on buttons & captionless controls- Now you can make buttons with icons.
- For compactness you can hide caption of control: new context menu for control at most duplicate caption buttons, so you can still access them when caption hidden.
- You also can move controls without caption with Alt button pressed.
Path for icon saved as RELATIVE to UTC, so you beter copy your icons into UTC folder. If you want help, make some useful icons and I put them into UTC redist at next update.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Bugs: 1) Unable to scale Label widget 2) Lock icon in left corner of Label widget not hidding when toggle caption is selected. Option to make the button the actual color instead of just border. (both would be nice) Still wanting for slider option also for volume control and (centered slider) color correction. Ability to Add Rectangles for background for a series of widgets to make it look like a section. Originally Posted by: elgarf  New update is ready. There is major change: Pictures on buttons & captionless controls- Now you can make buttons with icons.
@desmar, Label widget is just caption without content, so it's caption can't be hidden. Lock icon is always visible.
I'll think about sliders and rectangles.
Also locked widgets can't be moved or resized. So, check if your label is locked. I've added a "Region" widget, which can be used like section. Below is my controller for volleyball with regions and captionless widgets. It also have some scripting automations.  2019-03-17 (3).png (44kb) downloaded 17 time(s).
 1 user thanked elgarf for this useful post.
I've pushed update to UTC. 1) New Region widget to create groups or info for UTC operator. 2) Button to make all widgets, except regions "ghosted", so you can move/scale regions and don't affect another widgets. This button located in bottom right corner of UTC. First PostDownload Universal Title Controller
Joined: 12/29/2018(UTC) Views messages in topic : 10  Location: Siberia Was thanked: 1 time(s) in 1 post(s)
Small bug:
Duplicated widget creating under parent widget.
 1 user thanked David Kaz for this useful post.
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
Originally Posted by: gokily  I thought the lower part was only for formating time did not know it can be used for aliases.Thank you very much! Pozdrav Za što ti treba? Rukomet ili? Ja sam to za rukomet riješio kad mi isteknu 2min on sam skloni prikaz 2min, a starta ih i zaustavlja sa glavnim timerom. lp
Originally Posted by: David Kaz  Small bug:
Duplicated widget creating under parent widget. I'll fix it with new update, I think. It's not very critical. P.S. About new widgets: I'm not sure about trackbar/T-bar widgets, looks like they are not in UTC principles. I prefer UTC to make minimum API requests. Image widgets are useless if UTC and vMix are on different PC's. What new widgets you'd like to get?
Joined: 3/14/2019(UTC) Posts: 3  Location: Lodz Thanks: 1 times
For me it would be convenient to scroll the screens. My data does not fit on one screen and the automatic mouse scrolling does not work. One should use the bar on the right side of the window, which is a bit of a burden to perform and search for data. In addition, thank you very much for the opportunity to use this tool, which greatly facilitates my work during live broadcast
Updated UTC with: 1) password protection of controllers (click SHIFT+Lock button to protect your controller) 2) fixed scrolling by mouse wheel Universal Title Controller@Slavko, check the latest update.
Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
on widget Region add function "send to background" (for send widget to backgroud ) or simply send to background automatic
@chococrispis35, it should be background. Though, sometimes it not =( I'll fix it later.
Okay, I made some additional work on UTC =) Code:1) Now External Data Providers comes with UTC. You can add them from [Widget] menu very easy without searching .dll file.
2) I made a lot of work with NDI Monitor (found memory leak into example from NDI SDK), which should work now in any case, so "Register Filters" button now removed.
3) Small updates into Functions.xml:
*) FadeToBlack is now can be StateDependent function.
*) DataSourceSelectRow now support expressions into [Index] parameter.
4) Region widget now created below all widgets/
Try new NDI monitor. If it works good, replace your NDI monitor widgets, because they are cached into .vmc file. Universal Title Controller
Originally Posted by: elgarf  Okay, I made some additional work on UTC =) Code:1) Now External Data Providers comes with UTC. You can add them from [Widget] menu very easy without searching .dll file.
Try new NDI monitor. If it works good, replace your NDI monitor widgets, because they are cached into .vmc file. Universal Title Controller Hi, Region widget is still in front of other widgets. TY.
@yosik, changes doesn't affect saved controllers. So, removing and creating regions should help.
Joined: 3/25/2019(UTC) Posts: 2  Location: Londrina - Pr
Hi, first time here. Can Vmix UTC call the DataChangeIn and DataChangeOut function of GT Designer when I make some change in the value of the text fields? Thank you very much!
@fuimpa, looks like it working from the box. But you should use LIVE button, because all changes makes immediately. You can make hotkey for fast access to LIVE button.
Originally Posted by: elgarf  @fuimpa, looks like it working from the box. But you should use LIVE button, because all changes makes immediately. You can make hotkey for fast access to LIVE button. Hmmm, ill try that. All i want is to +1 the score on a scorebug and datachangein animation occur. You saying i need to disable live, make the change and enable live, is that? (sorry for my bad english)
