Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
 5 users thanked admin for this useful post.
22.0.0.48
* Added warning if existing vMix installation does not qualify for a free update to 22.
 6 users thanked admin for this useful post.
22.0.0.49
* Virtual PTZ behaviour is now more consistent with a physical PTZ including edges of the frame being cropped out when used with MultiView and Overlays. * Added checkbox in PTZ settings to have PTZ thumbnails always displayed on input previews even while moving. * Fixed Audio Settings button displaying error if already open. * Fixed some Facebook pages/groups not showing up if user has a very large number on their account. (> ~30) * Facebook destination will now stop the stream on Facebook just prior to stopping in vMix, previously vMix would be stopped first which depending on the processing time on Facebook may lead to a "stream has been interrupted" message on Facebook instead of an ended notice. * Fixed scrolling issue in input and mixer sections on some systems. * Improved sync on MP4 video playback * Fixed Web Browser input audio not working on some systems. * Fixed typo in Scoreboard 3- Lineup 11 template leading to inconsistent data source auto assignment.
22.0.0.50
* vMix Social updated Facebook source to now show a dropdown box of all pages an account has access to. Previously a box was provided to type in a page name which may have caused confusion due to Facebook security policies of only allowing admin access to pages.
* X-keys XKE-40 support added * Fixed Live Pause not working on Desktop Capture input on some systems. * Fixed padding issue with VLC input when bringing in RTMP 1080p sources. * List input now provides better performance when using images. * Display -> Outputs dropdowns support up to 300 inputs. * Fixed issue with MultiCorder activator * Fixed issue where Vimeo streaming destination did not show any streams when over 200 videos were in an account.
 7 users thanked admin for this useful post.
22.0.0.51
* Fix when starting overlay of GT templates that have had all animations removed. * GT animations will now only automatically trigger if autoplay/autopause are enabled. * Renamed Flash / RTMP input to Flash, as it is recommended to use Stream VLC input instead for RTMP. * Fixed stutter in VLC RTMP playback if frame rate is misreported by server. * Fixed Mark Out for some video formats occurring too early on some video formats. * Updated The Extreme scoreboard to work correctly when using countdown in clock fields.
22.0.0.52
* Fixed issue with Restart not working correctly with GT Tickers * Fixed issue where some YouTube accounts reports duplicate Stream Now streams, causing an error in vMix.
22.0.0.54
* GT: Added Blink Continuous transition * GT: Added Square/Rounded option for rectangle Stroke borders * GT: Fixed issue where custom image in a preset did not always override the template image. * Added support for plug and play MIDI and X-Keys devices while vMix is still running. (Important note: this will not resolve issues where devices are disconnecting on their own, in these cases, this indicates a system fault that is outside of our control).
* Added additional caching in vMix Social to help with long photo download times on Facebook servers * Updated Twitch streaming quality presets based on recommendations from Twitch team * Added "Auto" thread setting in streaming quality, which will select the optimal number of threads to use on high-core machines. Not applicable to hardware encoding.
 15 users thanked admin for this useful post.
shawntempesta on 3/27/2019(UTC), ask on 3/27/2019(UTC), hehsoy on 3/27/2019(UTC), chiscort on 3/27/2019(UTC), monamiga on 3/28/2019(UTC), slb5146 on 3/28/2019(UTC), corporatejames on 3/28/2019(UTC), QuiapoChurch on 3/28/2019(UTC), stigaard on 3/28/2019(UTC), raugert on 3/30/2019(UTC), avsoundguy on 3/31/2019(UTC), Longur on 4/6/2019(UTC), Reinaldo on 4/21/2019(UTC), sinc747 on 7/9/2019(UTC), STADIORADIO on 9/17/2019(UTC)
22.0.0.56
* Added "preview" overlay flag to vMix XML API to identify the difference between an overlay displayed on the output vs preview. * Fixed WAV file recording not working when using new vMix AVI format * Fixed large preview window showing up as blank when resetting camera input * Fixed error when using Replay on inputs that disconnect/reconnect often * Fixed Adobe Premiere import issue with vMix AVI when recording cameras without audio.
 12 users thanked admin for this useful post.
stigaard on 4/24/2019(UTC), BETech on 4/24/2019(UTC), ask on 4/24/2019(UTC), doggy on 4/24/2019(UTC), corporatejames on 4/24/2019(UTC), dunk on 4/24/2019(UTC), sinc747 on 4/25/2019(UTC), QuiapoChurch on 4/25/2019(UTC), sickley1 on 4/28/2019(UTC), raugert on 6/5/2019(UTC), linzmeister on 6/23/2019(UTC), STADIORADIO on 9/17/2019(UTC)
22.0.0.57
* MarkIn/MarkOut values added to XML API * Fixed issue when updating a GT title from multiple sources at the same time. * Fixed VST3 issue with Nectar 3 plugin
22.0.0.60
* NEW QR Code support in GT Designer. Creates a QR code image that can be dynamically updated from the vMix Title Editor, Data Sources and Shortcuts * NEW "Show Visible Toggle" option in GT Designer When enabled allows turning on or off selected images and text fields in the vMix Title Editor and Shortcuts. * NEW High DPI support in vMix User Interface for high resolution displays.
* NEW Animated GT title templates for all editions. Including Tennis specific scoreboards and QR code examples.
* Updated Restream API integration * Fixed audio corruption issue with some AJA capture devices * Substantially improved performance of Image Sequence, especially in 4K and 60p workflows. * Fixed rare bug with countdown timer after closing a title input.
 14 users thanked admin for this useful post.
ask on 5/22/2019(UTC), monamiga on 5/22/2019(UTC), rudyengels on 5/22/2019(UTC), stevespaw on 5/22/2019(UTC), mjgraves on 5/22/2019(UTC), sinc747 on 5/23/2019(UTC), jassantos on 5/23/2019(UTC), stigaard on 5/23/2019(UTC), ON.tv Channels on 5/23/2019(UTC), Ario on 5/23/2019(UTC), tonylightfoot on 5/24/2019(UTC), Brutuss on 5/24/2019(UTC), raugert on 5/25/2019(UTC), STADIORADIO on 9/17/2019(UTC)
22.0.0.66
* Added ability to select the Input Number when adding the input. * Added option to right click input "cog" menu to move an input to a numbered position instead of dragging. * Added ability to hide an individual input's audio mixer if it is not needed. * Added shortcut/activator templates for X-Keys XKE-124 Video Switcher Kit and upcoming XKE-64 Replay Kit. * Added scrolling support to Data Sources source toolbar. * Added Fault Tolerant option to MP4 recording. Requires using vMix Video Tools to index before use in some video editors. * Added "Increase Buffer Size" option when adding an NDI input. This is useful for smoothing jittery video of NDI-HX sources on some networks at the expense of latency. * Added "High Output Performance Mode" in Settings -> Performance. Improves render time when outputting 4K60 video when used with high end graphics cards. (GeForce 1080+) * Reduced GPU Mem usage of Web Browser input by over 50%. * Various fixes and improvements to vMix AVI * Fixed upside down video in MultiCorder with some types of sources. * Fixed MP3 playback issues with some files. * Fixed issue where a broken Stream Deck profile could crash vMix. * Fixed issue where some GT title elements would load up hidden from a preset if they were previously hidden by a transition. * Fixed Triggers list showing incorrect input numbers. * Fixed Triggers not activating on use of T-Bar. * Fixed issue where some spreadsheets may have millions of blank rows that were being imported causing high memory usage in vMix. Limited Excel source to importing only first 20,000 rows to prevent this. If more than 20,000 rows are needed please contact us! * Fixed MultiView layout setting not saving correctly in Preset. * Small performance improvements across the board!
 30 users thanked admin for this useful post.
ask on 7/22/2019(UTC), doggy on 7/22/2019(UTC), tkachuk.alex on 7/22/2019(UTC), Slaver on 7/22/2019(UTC), dunk on 7/22/2019(UTC), Omaha Hockey Network on 7/22/2019(UTC), monamiga on 7/22/2019(UTC), BETech on 7/22/2019(UTC), chiscort on 7/23/2019(UTC), elvis55 on 7/23/2019(UTC), sinc747 on 7/23/2019(UTC), raugert on 7/23/2019(UTC), edhorn on 7/23/2019(UTC), Aaron Rebbeck on 7/23/2019(UTC), cookdoeyl on 7/23/2019(UTC), stevemol on 7/23/2019(UTC), Gunnar on 7/23/2019(UTC), STADIORADIO on 7/24/2019(UTC), LiveSports on 7/24/2019(UTC), avsoundguy on 7/24/2019(UTC), StepBackInTime_TV on 7/24/2019(UTC), NewsworthyVision on 7/24/2019(UTC), stevespaw on 7/24/2019(UTC), Longur on 7/25/2019(UTC), ON.tv Channels on 7/25/2019(UTC), Video Dave on 7/25/2019(UTC), AgentPete on 7/26/2019(UTC), doa on 7/26/2019(UTC), h2video.nl on 7/26/2019(UTC), corporatejames on 8/9/2019(UTC)
22.0.0.67
* Fixed issue with MP4 Fault Tolerant recordings when Audio Bitrate was higher than 192 Kbps. * Fixed issue with MultiCorder when a source is offline. * Added support for latest Bluefish Nitro capture drivers.
 8 users thanked admin for this useful post.
22.0.0.68
* Fixed issue with TCP API where vMix may slow down after a few hours of constant API use. This should resolve the performance issue seen when using apps like Scoreboard OCR.
* Fixed issue where StreamDeck may not reconnect to shortcuts after restarting vMix.
ask on 9/14/2019(UTC), BETech on 9/14/2019(UTC), comporder1 on 9/15/2019(UTC), DetoxX on 9/15/2019(UTC), dundurs on 9/15/2019(UTC), stevemol on 9/15/2019(UTC), raugert on 9/15/2019(UTC), avsoundguy on 9/16/2019(UTC), monamiga on 9/16/2019(UTC), STADIORADIO on 9/17/2019(UTC), GS Webmaster on 9/19/2019(UTC), mavik on 9/19/2019(UTC)
22.0.0.69
* New login method for Facebook which utilises the user's default browser. This is now used for both vMix Social and vMix and will allow us to adapt to Facebook changes more rapidly in the future.
* Fixed issue logging in to Twitch
* Replay fix for ReplayUpdateSelectedInPoint/OutPoint not using correct time where previous footage had been automatically deleted. * Replay fix for ReplayMoveSelectedInPoint when it was used to move beyond current out point. * Fix for JLCooper controller no longer responding when using it alongside other controllers with activators.
 9 users thanked admin for this useful post.
