Record and livestream with different audio
I am a new user of vMix HD version. I have a broadcast that I live stream and also record MP4 to my computer. I would like to be able to mute the audio on the live stream output for a short time in the middle of the broadcast, but not mute the recording to the computer. Is this possible? If so, how?
Joined: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
You could use Audio Bus A for record. Simply activate A for all the inputs you need and select it in recording settings.
Then mute the master audio when you need to during the stream.
Marc
Audio Bus A is set for the main auditorium and Bus B is set for external output of video and audio to another auditorium using a Decklink Mini Monitor.
