Joedub1421
#1 Posted : Friday, March 15, 2019 9:04:14 AM(UTC)
Joedub1421
Curious to know what are if any major differences between using Newteks native NDI software versus using vMixDesktopCaptureNDI? Any major performance differences?
kane
#2 Posted : Friday, March 15, 2019 11:42:12 PM(UTC)
kane
NDI Scan Converter (included with NDI Tools) runs inside the GPU and offers up to 60fps performance with little CPU impact. However, because of this design it requires Windows 8.1 or higher OS. If you are on Windows 7, then the vMix Desktop Capture would be what you need to use.
I have both. The are free, so why not!
Kane Peterson
NewTek
