Infinite Count Up Timer (Reverse Countdown beyond 23:59:59 )
Joined: 1/16/2018(UTC) Posts: 37 Location: Bern, Switzerland
Thanks: 4 times Was thanked: 4 time(s) in 4 post(s)
I'm looking to build a title counting passed minutes and hours for a multiday livestream (~100 hours).
As far as I see, the Reverse Countdown title only allows for counters that run for less than one day. Is there a way around this and if so, is there a way to only show passed minutes and hours without seconds?
Thank you
{0:hh:mm}
never seen a clock that can count past 23:59:59
Add some days to your clock (other text field)
try this: Duration 23.59.59 trigger OnCountDownCompleted SetText +=1 to your days field trigger OnCountDownCompleted StartCountdown
or build a custom coded title with clock
