markusnygard
#1 Posted : Tuesday, March 12, 2019 5:36:18 PM(UTC)
markusnygard
Hi
Is it possible to start recording on a second vMix(PC2) for example when you start your Intro on your main-vMix (PC1).
As this
On PC1 you start intro that triggers a script that starts the command startrecording on PC2
It would be a great way to not forget to start recording, and to use 2 PC is just a way to do load balance.
br markus
#2 Posted : Tuesday, March 12, 2019 9:03:00 PM(UTC)
one has to love the search feature ;-)
from 3 years ago : Using a Script to Trigger an API command on a second VMIX [SOLVED]
markusnygard
#3 Posted : Tuesday, March 12, 2019 9:39:05 PM(UTC)
markusnygard
I didnt find it because i tried to search startrecording :(
br markus
sinc747
#4 Posted : Wednesday, March 13, 2019 1:44:10 AM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Please note that you will need vMix 4K or vMix Pro to use scripts.
vMix Comparion Table
- Tom
