Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
Could it be that lists won't "Auto Next" images since the last update?
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
I suppose you mean "PlayList" as the List option is only for Video, Audio and PlayList files.
The PlayList is still fully functioning over here.
Regards, Rudy
Oh, really? I was using "List" for over 2 years for .jpg and videofiles and it worked. It showed the images for about 10 seconds and then moved on to the next one, but it doesn't work anymore since the last update. Martin, can you please enable it again and make it possible to use lists for images as well? I really, really need that feature. Update: Just found out that you definitely changed something in the latest Vmix version: Quote:22.0.0.50
* vMix Social updated Facebook source to now show a dropdown box of all pages an account has access to. Previously a box was provided to type in a page name which may have caused confusion due to Facebook security policies of only allowing admin access to pages.
* X-keys XKE-40 support added * Fixed Live Pause not working on Desktop Capture input on some systems. * Fixed padding issue with VLC input when bringing in RTMP 1080p sources. * List input now provides better performance when using images. * Display -> Outputs dropdowns support up to 300 inputs. * Fixed issue with MultiCorder activator * Fixed issue where Vimeo streaming destination did not show any streams when over 200 videos were in an account. Unfortunately it doesn't work anymore :-/
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4790 time(s) in 1644 post(s)
Image support in Lists was always an unsupported feature, so we made some changes to make sure it worked more consistently in .50. However since images have no duration, it won't automatically move to the next image without manual intervention. Setting it back to 10 seconds is not really useful, and I would recommend using the Photos input as that is designed for custom durations.
Hm, that's sad. Any chance that you'll add the option to set the time for images in the list in the near future?
(transition animations would be welcome as well, just like in instant replay or photo inputs)
I really need a list with rotating images and videos and using list for the videos and photo input for the images wouldn't be very handy in my case.
If not possible in the near future, is there any chance for me to downgrade to Version .49?
Joined: 5/13/2021(UTC) Posts: 3  Location: Valencia Thanks: 1 times
Hello, the same thing happens to me, I have been using List (version 21 of vmix) for years as a launcher for videos and images and it was more useful to do it this way than in photos (since I mix videos with photos) and in playlist it is less useful. It would be very good for me to return to the previous implantation.
